HOW TO: 2013+ LED Tails into a 4th Gen
sawz
Aldie, VA
2015 Ram 1500 QC
Does anyone have the part numbers for the connector and pins for the connector circled in red in this picture?
sawz
Aldie, VA
2015 Ram 1500 QC
I have installed my 2013 LED Sport tails onto my 2015 Ram 1500. I made adapters per the instructions found in this thread and the part numbers provided by 00R/T. Thanks for the information and work that went into figuring this out.
One item I noted with my installation. I did not install load resistors in my harness and do not have any errors or hyper flash issues, the tails works as they should and I'm not sure why! I also have not set the LED tail options with AlfaOBD.
ricky_bobby
Wake County, NC
6.7L Cummins
^Would you have enough parts to make another set? And did you add the wire for the "fault sense?"
sawz
Aldie, VA
2015 Ram 1500 QC
No, sorry. I don't have any extra parts left. I did not add the fault sense wire.
Cesar592
3.6 pentastar
¿Qué cableado de calibre usó para estas partes que enumero r / t00 son para un conjunto de luces traseras o es solo para una
BlownGP
Houston/Baton Rouge
4.1 LED TAIL SIDE WIRING
If you sourced the LED pigtail from a junkyard, you will need to move one pin, and remove and discard another, as they are not all in the correct location for the 2013+ LED Tail Lights. Below is a picture of the contact that must be moved and removed and discarded.
Does anybody have a pic of what he's talking about?
E
emjohn4
I can't edit my original posting from 7 years ago! (That is an engineers' cheerful attempt at sarcasm! :) )
Here's the original pic for that step:
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Tyler Welch
Wichita Falls
6.7 Cummings
I just installed the 4TH GEN RAM TAIL LIGHT ADAPTER (V2.0) purchased from Retroshop with a set of led tail lights. I'm currently getting a parking light out and reverse light out. Everything is functioning correctly after install. To get these messages to go away do I need to change anything with AlphaOBD? I have not changed any settings yet.
Thanks in advance.
kegger
3.6 pentastar
Thanks in advance.
I had to set mine in alfaobd to led. I've set everything to led and so far zero issues. I also made my own adapter harness, not sure that makes a difference or not though.
Mpgrimm2
Preferred Vendor
SC
5.7L
Thanks in advance.
You shouldn't need to change anything with those adapters from Jeremy. (I had the v1 w/ large resistors on my 13 ram 1500).
Did you contact him to ask about it?
M² Mods.
BlownGP
Houston/Baton Rouge
Never got around to saying thank you..
It was a fun project and got the lights working after a few trial and errors. lol
