How to 4th Gen SLT Tow hook Install
D
dan1911
Fairbanks, Alaska
Need help finding tow hooks, 2017 1500 Laramie crew cab, plastic bumper with plastic inserts. Plastic bumper?
I have the steel bumper with the inserts (I believe they are all plastic).
Call your local Mopar dealer, give them your vin# and they should tell you the part numbers. Then just do a google/amazon/eBay search for those part numbers
Sent via telepathy
Quyonmob
Canada
C7BCB663-3950-499B-8B0F-4AC35C4F8552.jpeg 55735025-EA3B-41CF-89B3-A71FE26B2EBB.jpeg 3EE52E11-179D-4B9D-A12B-012DFB6FCC8C.jpeg So if you forgot to get the brackets like I did, there is a solution.
Mopar PN: 52855201AB
It’s listed as a trailer hitch and bumper bracket for a 2011 Dakota. It looks nothing like the factory bracket, but fits and lines up PERFECT.
California
Hemi V8
Quyonmob
Canada
I just ordered my tow hooks from Mopar. Is the bracket not included?
Yes, the bracket is included. I bought mine off a wreck for $100, seller didn’t take the brackets off the wreck.
Apprently this issue is common buying used.
California
Hemi V8
Gotcha! What did you use for your bezel? Did you reuse the existing cover and cut it?
GreatShotKid
Colorado
Pictures don't appear to be working again, what about on someone else's end?
Deepjeep85
5.7L
I have made some tow hook brackets that will allow you to install stock tow hooks mounted correctly on an express/sport model bumper...hit me up
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
body shop put my tow hooks on backwards
The open part of of the hooks should face outwards
This is my 2016
on my 2009, i did not need the fog light bar
so the bumper bezel had to be modified
This guy installs tow hooks on a Gen 4 Ram 1500 with metal bumper.
I may be wrong, but to me, the hooks are on backwards
This guy installed the tow hooks on a Gen 4 Ram with the Sport bumpers.
He installed the hooks the way they should be, to my way of thinking.
He cut the plastic insert to fit over the tow hooks
2021 Ram tow hook installation
