Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to Add Automatic Temperature Control (ATC) to a Manual Temperature Control Truck
Discussion in '4th Gen DIY' started by DeereGuy, May 16, 2017.
  1. jon C lawrence
    jon C lawrence Junior Member
    13
    Jul 7, 2020
    chubbuck ID
    Ram Year:
    Engine:
    6.7 cummins
    @Mpgrimm2
    i do not get defrost with atc and when i put it on defrost manually it blows out the dash only
  2. Mpgrimm2
    Mpgrimm2 Senior Member Preferred Vendor Supporting Member Military
    5,083
    3,239
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    2019 Laramie QC (5th Gen)
    Engine:
    5.7L eTorque
  3. ManualCummins
    ManualCummins Senior Member
    32
    187
    73
    May 3, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    Every issue I’ve ever had has been cured by a brand new module I think the ultimate answer is the only use a new module
    I even have an 18 module in my 14
  4. Mpgrimm2
    5,083
    3,239
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    Engine:
    5.7L eTorque
  5. Bill507
    Bill507 Senior Member Military
    60
    326
    237
    Dec 26, 2014
    New Orleans
    Ram Year:
    Engine:
    Its Christmas early! Cant thank m2mods enough[​IMG]
    Sent from my rotary telephone using Tapatalk
    [​IMG]
    Now in auto[​IMG]
  6. Bill507
    60
    326
    237
    Dec 26, 2014
    New Orleans
    Ram Year:
    Engine:
    My install went flawless when enabling Single Zone ATC and my steps below per M2mods:
    Include your
    - Year/model/trim of truck/original fan speed>> 2014 1500 CC 5.7 with factory 8 spd
    - Original radio/new radio model (& new pn) RA3 with dealer activated NAV. /// upgraded to RA4NA and 7" cluster
    - 8.4 HVAC module PN (bought new or used?) factory module.
    - Fan resistor you used (New OEM, Used OEM, or Clone?) N/A
    - Conversion Harness: ie 4 or 7 speed w/Sgl Zone ATC support N/A
    - Cabin Temp Sensor and/or humidity sensor (New or Used or Clone?) harness, sensors provided my M2Mods
    - what you used to program: AlfaOBD PC or Android/OBDLink MX BT & steps you did (battery vs radio fuse pull between steps?) AlfaOBD Android with newest update
    --> & what SW version of AlfaOBD you used!? newest v2.1.9.5
    - Anything else that may be relevant >>>>
    * I pulled BATTERY HOT cable before connecting harnesses and sensors
    * Reconnected battery and verified HVAC , SirusXM and backup cam were GTG
    * Did 1st AlfaOBD change to DUAL Zone.
    * shut key off, pulled Afa from port and disconnected battery again
    * waited just over an HOUR
    * Connected battery and verified HVAC was now DUAL ATC when Sirus and cam looked good. all HVAC settings worked
    * Did 2nd Alfa change to Single Zone. repeated, shut off, pulled alfa and disconnected battery for an hour
    * reconnected battery, checked HVAC and all was GOOD. Manual / AUTO worked perfectly.
    -- several drive cycles now and all is great. One of the BEST mods yet..
    Sent from my SM-T720 using Tapatalk
    Mpgrimm2 likes this.
  7. Austen
    Austen Senior Member
    285
    137
    Jul 30, 2018
    Missouri
    Ram Year:
    Engine:
    PFI! Will someone please tell me the part number for the SINGLE zone ATC HVAC controls? My current setup is in the attached picture. My truck had the factory 8.4 but I installed @Mpgrimm2 single zone ATC harness & temp sensor as it did not have ATC from the factory. I would like to make it complete and look correct with the auto button. Thank you in advance. I have also attached a picture of the controls I'm looking for. [​IMG]
    16' CCSB 4X4 G56 2500 6.7 SLT, CTT tuning, UAQ, Customtronix Enzo, Single Zone ATC
    [​IMG]
  8. Mpgrimm2
    5,083
    3,239
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    Engine:
    5.7L eTorque
    Ricks Ram and Bill507 like this.
  9. Austen
    285
    137
    Jul 30, 2018
    Missouri
    Ram Year:
    Engine:
    That's odd, I'm sorry about the pictures! Yes sir that's exactly what I'm looking for. Do you have any that I'm able to purchase that you have already converted/built? I'm trying to avoid having to run without the controls. Also what would you price be on that? I thought there were trucks that came factory with single zone automatic climate control?
  10. Mpgrimm2
    5,083
    3,239
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    Engine:
    5.7L eTorque
    Austen likes this.
Share This Page
