How To: Add Factory Keyless Enter N Go
kp4243
NC
Alright guys need some input. I had everything working once I installed the passive entry and working fine minus the C151 code. I got it cleared finally about a month ago but now... no matter what I do I cant get the tmps sensors to read at all. Any ideas? Confident its something I did while trying to clear the code. Also does anyone know exactly which items I would need on/off for the tmps system? Just want to make sure I didn't turn something on or off that I wasn't supposed too.
Alexx
Los angeles ca
Just want to thank everybody on this post just got my keyless go done today i have everything for passive entry just lazy to take apart my doors bit so far keyless go is workin perfect
Jason Flanigan
Lexington
I had this same issue and it was caused by the remote start antenna. Also my key range was significantly weak.
kp4243
NC
I don't seem to have a problem with either of those. They are working fine.
chrisbh17
I didnt quite understand that fix either, unless they managed to find a new old part number hub? Since the current hubs have the remote start antenna built in....
Jason Flanigan
Lexington
I didn't understand it either, but I placed my remote start antenna directly on the side of the hub then everything started working. My truck is a 2016 2500 and it had an extension wire on the harness that I tried to use. When I placed antenna on the wire I had no tpms and no key rang. After going directly to hub everything worked and I did test every time i used the extension everything stoped working.
Might not be same issue for you but I'd check the antenna if it's not built into your hub.
kp4243
NC
Honestly it act like an antenna problem. But my remote start was built in.
NC
If I wanted to activate keyless entry on a truck with power locks like a 2011 where would I perform this in alfaobd on a 2011 ram 2500? In the RKE?
J
Jimmy07
I’m not 100% on a 2011, and I don’t have alfa with me right now, but on 2013+ rams, it would be VehicleConfig 3- RKE system present.
Jason Flanigan
Lexington
With it being built in not sure how to test it easily. Alpha never said I had an antenna issue. No matter how I had it hooked up it always read it as present and when I ran the remote start antenna test it said it was good.
If you have alpha I'd try the antenna test just to see what it comes back with.
kp4243
NC
I’ll try it again. It’s been a month or so but i want to say I did the antenna test. But I don’t remember what it said.
NC
We have tried to set rke to present and still nothing. Could it not be taking the change for one reason or another?
J
Jimmy07
I guess I should ask, you’ve already added the correct win module and key fobs (basically, the factory remote start kit for 2011s), correct?
NC
Its not my truck so idk, ill have to ask. All I know is its a ram ST with power door locks.
J
Jimmy07
At the very least, the win module needs to be changed, along with a fob.
Alexx
Los angeles ca
I just finished my truck and i have a an extra set of handles push button nd all the antenas with pigtails any offers handles are silver
Ricks Ram
We just finished my buddy's silver 19 Bighorn Classic. Those would have definitely come in handy. Took a while to get the parts especially interior antennas. You might want to list them in the for sale section to get more exposure.
HTXRamExp
Houston, TX
I might be interested if these haven't sold yet. Not really interested in the door handles though.
BZ2500
Belize
6.7 cummins
Getting ready to start this project. Just a few questions.
Are we still butting the door antenna on the B pillars?
Are we still pulling the wires through the boot for the door handles? Wasn't there a connector kit that we could have pinned to the door harness connector?
VLG6963
