Adam Gregg
- Jan 26, 2021
- 26
- 3
- Location
- Las Vegas
- 2019 Ram 1500 Classic Hemi
- 5.0 Hemi
68319680acYou’re buying another hub? What hub do you have now?
I finally bought a second fob (figured I should have a spare) when I program the second fob, so I have to do rf hub reset? And will the truck die and all that like the op says? Or was that just because of adding the new hub and programming the key simultaneously?
The one you have now should be good.
Since I have the 2019 classic I think it is the wrong hub. I think that I need this hub 68363199AC. What do you think?
We did my buddy's 2019 classic and it worked fine. Remember you will need the bypass cable from M2mods to enable codes with the alfa on the 18 and 19 trucks.
Thank you for confirming. It must be at one of the connectors.Hub isn’t your problem as long as it was new. I used the same version.
Delmonico Red
1UJ81NRVAI - Front Driver
1UJ86NRVAI - Front Pass
Does your hub also supports proximity for the door handles?I got the same version hub as you except mine an AE not AC and I also have a ‘19 Classic. As long as it was a new hub never used it should work.
this might be the issue with programing the keys. My hub is actually 68363199AC. They sent me a different hub then what I ordered.
Hi, How long did it take to program the key the first time?
Awesome, thank you for your help I got some more parts come in my way and I’ll try it again for round two! LOLPretty sure that hub should still work. And yes, I have passive entry and push start.
That is the end that plugs into the RF Hub, not the end you wire into. If you look at the back flaps on the connector real close you will see they are numbered. One will say 2 and 9 and the other says 11 and 20zHi, can I get someone to let me know if this picture is the front view or the rearview of the C2 connector?
