I may be able to get a set of HID headlight assembly’s and would like to install them on my non HID quad headlight RAM. Since I’m getting the whole headlight assembly what would I need to hook them up? Is it just a simple wire harness?
What are you actually referring to when you say HID headlight assembly. Are you getting a set of HID bulbs to install into your headlight housings? Or, are you getting a set of housings that you want to install HID bulbs in?Headlights coming from a 2012 and going on my 2015
You mention installing them on your “non HID quad headlight ram”, but you have a 2015. All 2013+ rams have either quad or projector headlights. All 2009-2012 rams have either dual or quad headlights. If you’re getting a set from a 2012, the best they will be are the quads, which you already have (unless you have projectors right now, and are wanting to go with quads).
