Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How To Add rear Park assist
Discussion in '4th Gen DIY' started by skuppy069, Oct 6, 2018.
  1. the_nid
    the_nid Junior Member
    41
    22
    Feb 16, 2021
    Bristow, Virginia
    Ram Year:
    Engine:
    3.6 L V6
    That's the part number I bought
  2. GWR Ram
    GWR Ram Senior Member
    66
    124
    61
    May 28, 2019
    Middleton, Idaho
    Ram Year:
    Engine:
    6.7 Diesel
    Your front sensor light should be on until you install the sensors.
    I would check the wiring again.
    Where did you buy the module?
  3. skuppy069
    skuppy069 Senior Member
    709
    284
    Feb 26, 2017
    canada alberta
    Ram Year:
    2018 1500 cc
    Engine:
    Are these oem sensors ?
  4. GWR Ram
    66
    124
    61
    May 28, 2019
    Middleton, Idaho
    Ram Year:
    Engine:
    6.7 Diesel
    I don’t think so.
  5. the_nid
    41
    22
    Feb 16, 2021
    Bristow, Virginia
    Ram Year:
    Engine:
    3.6 L V6
    I bought the module on eBay, but if it was defective I would expect to see something in the faults with Alfa. The sensors are Bosch...bought those on eBay as well.
  6. SRich2015
    SRich2015 Senior Member
    261
    109
    Jul 23, 2017
    USA
    Ram Year:
    Engine:
    Those are the same ones I bought and have worked great for me. I would say it is in wiring or your canbus wires are reversed.
  7. skuppy069
    709
    284
    Feb 26, 2017
    canada alberta
    Ram Year:
    2018 1500 cc
    Engine:
    I won’t be the can bus wires as he can connect to the module and if it was reversed the whole truck would be freaking out .
    It’s either the sensor wiring like you have mentioned or bad sensors .
  8. the_nid
    41
    22
    Feb 16, 2021
    Bristow, Virginia
    Ram Year:
    Engine:
    3.6 L V6
    Pretty sure canbus is correct. I tried reversing the wires and got errors stating that the park assist was not found. I bought new sensors and will try them when they get here.
  9. GWR Ram
    66
    124
    61
    May 28, 2019
    Middleton, Idaho
    Ram Year:
    Engine:
    6.7 Diesel
    Keep us posted.
    I have seen guys get bad sensors in the past here on the forum.
  10. the_nid
    41
    22
    Feb 16, 2021
    Bristow, Virginia
    Ram Year:
    Engine:
    3.6 L V6
    Got the new sensors in and seeing basically the same thing...though when I run the wiring test it's coming back with only 2 sensors having fault codes. I check the voltage at the rear harness to make sure the power and ground weren't reversed, they were not. I suppose I could have miss-wired some of the sensors out of order, but that wouldn't cause them not to work. At this point I'm wondering if the module itself is bad? One thing I did notice is that when I clear the codes and then put the car in verse up against my garage the sensors seem to come on for a split second before getting the system fault again. Though could be just nothing.
Share This Page
