How To Add rear Park assist
SHERMAN ROBBINS
Dallas
Sent from my SM-A205U using Tapatalk
c655a6c1-392b-409c-8c47-87bbc04849c6-png.207419
These are confirmed working sensors. I haven't found any from other sellers that work. These actually have the Bosch labeling on sides of sensors the pic is for 8 sensors I believe they are $22.99 for 4.
Michael Trevisan
Middletown CT
So you think could just be bad sensors why I'm getting that error message, and thank you for the help I appreciate anything
SHERMAN ROBBINS
Dallas
Yes more than likely. I got some sensors from another seller when I installed my system and my truck threw the service park assist message. The way I found out it was the sensors was I did my back sensors first and then the front my back sensors were from a seller who sold me my harness and sensors that where factory. So I took the ones I ordered and put one in the back with the factory sensors and the back then threw the service park assist message. Someone else got the same message when buying sensors from unconfirmed sources.
S
skuppy069
canada alberta
2018 1500 cc
View attachment 208780 I sent this to another member to try out . It’s a first go so will see when its installed if there are any suggestions for improvement etc .
It’s about 150 Canadian in parts roughy and about 8 hours of work .
I made another setup as had enough parts to make one more etc
If some one is interested in adding this setup to there truck let me know .
Got the process down to 6 hours with a wire rack and Some organization
Michael Trevisan
Middletown CT
Ok so I got the rears working but the front sensors the minute I put it into drive it goes double red and aren't working correctly.
Any ideas
Dkloven34
MI
Do you need the u connect 8.4 radio to run the park Sense, I have the ra2 5.0 would it still work ?
Idagrizz
Skuppy do you still have the wire setup available?
Brad360
Ok Guys a little help and advice please, no matter how I set the setting I still have the Off message in the front of the truck is this normal? I turned off everting short of park tronics... What should the normal setting be? it works with every thing OFF as of now I only have the sound and part T on. Please advise gents
Michael Trevisan
Middletown CT
Okay need a little help I am getting every check engine light and sensor malfunctioning due to lost communication to the bcm sense installing park sense and it's saying can bus C negative is the problem
Thanks for any help
SRich2015
USA
Thanks for any help
Did you check your ground at the can bus block coming from the park module?
