How to add remote start to 2017 Ram
G-Ride990
Administrator
Administrator
Chandler, AZ
I'm doing an install on my buddies 2019 classic warlock now. He got the pin number printout from a dealer but alfa is telling me the pin is incorrect.
Has anyone experienced this?
Brew99
Victoria, Canada
Where are you guys finding the key fob overlays? I’ve looked on Amazon and eBay and all I see are new complete fobs
1500ram12
5.9L Cummins
KAWIHEN Keyless Entry Remote Key Fob Skin Replacement for Chrysler Town AND Country Dodge Durango Grand Caravan Journey Ram 1500 2500 3500 Jeep Grand Cherokee GQ4-53T M3N5WY783X IYZ-C01C https://www.amazon.com/dp/B0859BM3Y8/ref=cm_sw_r_cp_api_glt_fabc_PR9J1M5Z5396QHB9YS8T
Replacement Keyless Remote Fob Key Shell Case Replacement Fit For Dodge Durango Grand Caravan Journey Ram 1500 2500 3500 Jeep Grand Cherokee Ram 1500 2500 3500 IYZC01C M3N5WY783X GQ4-53T https://www.amazon.com/dp/B07G835ZV5/ref=cm_sw_r_cp_api_glt_fabc_HH2GFBC1Q9W2GC8WX0RB
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
1500ram12
5.9L Cummins
Both currently unavailable it says, and no eta
Odd. I just checked both links and added to cart and are available
Brew99
Victoria, Canada
Ok thanks. Figured it out. It says unavailable when shipping to my Canada address, but if I changed it to my mother-in-law’s in the US, it’s $10. Of course not available on Amazon Canada
FWB-Gator
Fort Walton Beach, FL
I'm new to the forum, and I have to say it's been fascinating reading the incredible information people post here. It's definitely addictive!
I do have what I'm sure is a dumb question, but what the heck. I saw on some earlier messages in this thread a method that involved ground pin 11 on the BCM C1/A connector. For the heck of it, I thought I'd just see how accessible that is. I have a 2016 1500 Bighorn (but I doubt that makes a difference for this question). Is the BCM, and especially that connector, really hard to get to? First, I can barely reach up there and grasp it. And if I disconnected it, all those bundles of wires for the BCM connectors are heavily taped together, so it appears there'd be no slack to access it even after disconnecting. Am I missing something about how to access it? Or (and this is my guess), is my old body getting so stiff that I just can't contort myself the right way.
Once again, thanks to everyone that posts here. Great reading!
Brew99
Victoria, Canada
Your observations are basically correct. It is a little easier if you remove the panel below the steering wheel (not sure what that's called), but as you have observed, the wires are bundled together, and don't offer much slack. I fought my way through it, and after figuring out how the connectors and housings are released, think it would be much easier the second time around.
FWB-Gator
Thanks. So did you disconnect all the connectors on the BCM? If so, does that allow you to pull the whole bundle to where you can work with it better?
By the way, a bit of claustrophobia doesn't help!
Brew99
Victoria, Canada
I think I only disconnected one right beside it, which gave me a little more slack. Was able to lie on my back with feet on the ground and do it. Not much room, and somewhat uncomfortable but doesn’t take too long
FWB-Gator
Great! Thanks. Sounds like a job for my 27 year old son!
VictoryLapMB
Manitoba
Thanks guys. Added to my 2018 Ram 1500 just added the hood latch. Programed a new fob to my push start and its all working.sCoPkdI.jpg
MikeDee
MA
The p/n for my 2015 rf hub is 68234884AE. Anyone know if that will work or do I not even need to worry about that?
G-Ride990
Administrator
Administrator
Chandler, AZ
I still can't reset the RFH on my buddies 20109 warlock. This is the second time now we have gotten the pin number from a parts department. Anyone have any ideas?
MikeDee
MA
please disregard. I found my answer.
Brew99
Victoria, Canada
Are you certain that the pin code the dealer is giving you is for the RF HUB? It is different than the key code one. Another option is to try the Chrysler Pin Puller app from the Google play store (if you have an android phone/tablet). I used this app, got the code, and it worked great with AlfaObd
G-Ride990
Administrator
Administrator
Chandler, AZ
Yeah they are giving us the print out that has both codes on it.
Also tried chrysler pin puller but I couldn't get it to work on his truck. Might have to have the dealer add the sales code at this point
00R/T
CT
I’m not sure if it was mentioned already, but I figured I’d comment in case someone finds this in the future. Even though the 13 models use an external antenna and the Mopar kit comes with a new RF hub, the factory hub is capable of remote start and you can enable it the same way as on the newer models.
skuppy069
canada alberta
2018 1500 cc
Like the original rf hub in the truck that came from the factory without remote start enabled ,no hood latch etc ?
Thanks and I’m curious on this now
kad
Hudson Valley, NY
5.7L HEMI
This is the first I've heard of this. Just the 13s or the 14-16s as well? (I think the newer internal antenna hubs started with the 17s). Where did you come across this info?
-K
