Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to add remote start to 2017 Ram
Discussion in '4th Gen DIY' started by Moab_Rockstar, Mar 10, 2017.
  1. Stelios
    Stelios Member
    58
    74
    Apr 2, 2018
    Bay Area
    Ram Year:
    Engine:
    Wait so you just had to get the hood latch for the wiring side of it?? I have the plug by my hood latch too but unsure if I need to run wires thru my firewall and connect to my bcm as well. Its a 2017 RCSB so I know its wired for a bit more than its optioned for
  2. ameldorf
    ameldorf Member
    37
    55
    62
    Jun 18, 2020
    Lenoir, NC
    Ram Year:
    Engine:
    Correct. Connector plug and wiring already there from factory. Only things I purchased for this project were the hood latch, key fob overlays, and the 4 digit pin (no desire to interact with dealership).
    Stelios likes this.
  3. Stelios
    Stelios Member
    58
    74
    Apr 2, 2018
    Bay Area
    Ram Year:
    Engine:
    What cab configuration do you have? And it fired up with the remote after alfaobd? Dang, Im excited now. About to order the latch then haha
  4. ameldorf
    ameldorf Member
    37
    55
    62
    Jun 18, 2020
    Lenoir, NC
    Ram Year:
    Engine:
    2019 Classic Tradesman w/ Express 5.7 RCSB. After the changes w/ Alfaobd, I had to drive around few miles, but when I got back to house, remote start worked.
  5. ameldorf
    ameldorf Member
    37
    55
    62
    Jun 18, 2020
    Lenoir, NC
    Ram Year:
    Engine:
    May be a dumb question, but here goes....
    Is there a way to disable the horn when remote start?
    I don’t have the option on the 8.4 touchscreen to turn off for remote start, just turn off when locking. I’ve driven and reset screen enough that I’d think it would show if an option. ‘19 classic that didn’t have 8.4 or remote start from factory if it matters.
  6. clifford15
    clifford15 Senior Member
    709
    340
    Sep 4, 2015
    Ram Year:
    Engine:
    CTD
    You need to set Cust.Prog.Feature Horn with remote start.
    It should show quickly in the same screen as horn with door lock.
    ameldorf and 1500ram12 like this.
  7. ameldorf
    ameldorf Member
    37
    55
    62
    Jun 18, 2020
    Lenoir, NC
    Ram Year:
    Engine:
    Awesome. Thank you!
  8. aimvee
    aimvee Member
    34
    67
    8
    Apr 28, 2019
    CA
    Ram Year:
    Engine:
    New hood latch on a 19 classic. Activated the remote start..
    Still getting hood open error..
    Any thoughts?
    Sent from my SM-G965W using Tapatalk
  9. 1500ram12
    1500ram12 Senior Member
    5,288
    2,083
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
    Was your truck pre wired for the hood latch?
    The you follow the instructions for the remote start?
    You may have to try a different ohm setting for the hood latch
    2018 2500 6.4L Hemi Tradesman
    1990 5.9L 12v Cummins W250
  10. aimvee
    aimvee Member
    34
    67
    8
    Apr 28, 2019
    CA
    Ram Year:
    Engine:
    Yes truck was "pre-wired".
    Followed instructions.
    Checked the wire was in pin 11
    Tried both 1k & 500ohm.
    Truck honks once and cancels.
Share This Page
