Kfield
So I have had a terrible time with the ANC system. After 2 trips to the dealer STAR has no clue on it after they replaced the amp. I inquired about disabling the system. STAR didn’t even know if it was possible. STAR want the vehicle to run some scans, but since it was not a drivability issue they would not pay for a loaner.
I didn’t want to fool with dropping the headliner and disconnecting the mics. So I obtained a wiring diagram for all stereo units. All the ANC mics used the same color across all units.
I have the 8.4 Base.
Locate Amp under driver seat. Move seat all the way forward and all the way up to have room to work.
Disconnect the signal out harness, on mine the large white one. Closest to the rear of vehicle on amp.
(Note take picture of wire orientation Incase you want to reconnect later)
On the underside of the connector is a long flat pin locking mechanism, pry that up on the middle insert to release pin locks.
It raises maybe an 1/8th”
All my Mic wires were the 4 sets on the left of the connector.
Looking at the harness the ANC wire colors are (Main color/ Stripe Color)
Mic 1- Brown/Orange + | Brown/Violet -
Mic 2- Brown/White + | Brown/Grey -
Mic 3- Orange/Dark Blue + | Orange Dark Green -
Mic 4- Orange/Green + | Orange Blue -
Once wires are located looking in the connector you will see a white tab at the top of each pin hole
Use a small screw driver, pick tool, or (what I used) a paper clip to slide the tab up. The wire pin will slide out.
Once all pins are out reconnect the connector to the amp, and test all systems to make sure function properly.
Your ANC will now be disconnected.
*** PERFORM AT YOUR OWN RISK***
I am not responsible for any mishaps or damage you may cause by performing this procedure.
