Viper_cobra
Hi all.
Have now got my AC-Cobra with the 8.0 V10 engine up running. However, I do not dare to run it since I don’t get any oil pressure. The engine has been sitting for 10years during the building process.
Is there a way to bleed the pump to get it working? I have moved the oil filter due to space iasues, and have tried to pump oil “backwards” through the hoses connected to the oil filter. When running the engine I notice the oil circulates with very low pressure/flow. There is a screw on the side of the timing chain cover to remove a spring if I recall it right. Should I do something with that..?
Ideas anyone?
Ideas anyone?
