PA Ram
Quakertown, PA
Anyone have an issue with no sound from rear speakers after old 8.4 To 8.4 4C UAQ ?
Not on mine, I have a 2017 Ram 1500 and upgraded to a 8.4 with nav from the 5 inch screen and then upgraded it again to the 8.4 UAQ.
Leveil22
On a 2013 how do I fix the A/C issues where you can’t control the temperature only high and low
SitKneelBend
St. Louis
3.6 Pentastar
If you haven't let it set for a little while after install through several power cycles/hours let that happen first. It should read the BCM and change the display.
SitKneelBend
St. Louis
3.6 Pentastar
It’s been in for 3 months so far
Try pulling the inline fuse for the radio in the engine bay for 15 minutes then plugging back in. Conversely you can do the same with the negative battery cable.
TwoGoatsOneRam
USA
Hemi 5.7 V8
Hello all! After months of lurking and reading 203 pages, I performed the upgrade but am left to ask for help.
4 days ago I performed 8.4 upgrade on my 2015 Ram 1500 Limited (5.7L V8). Original equipment was 8.4” UConnect (no CarPlay obviously). Bought the new 8.4 from a salvage yard which came from a 2020 Ram 1500 Big Horn/Lone Star 5.7L.
Upgraded to:
- 8.4” UAS(Q?) P/N: (P)68428539AC (Aptiv)
- Foruly RAM Media Harness (Amazon)
- UOIENRT Compass USB AUX Port (Amazon)
Install went fine, only hiccup was the connector orientation for the purple fakra didn’t fit in the port, so I swapped the plastic housing from the original and it clicked in fine.
NOW (4 days later) - everything works great with a few exceptions which are critical in my opinion:
1) Backup camera shows black screen with “…camera unavailable”
2) Steering wheel volume/tune controls do not work (everything else does)
3) Outside temp shows Celsius
4) SXM works fine but no SXM app in menu
5) Limited settings options — bought OBDLink MX+ and codes show VIN mismatch, camera disconnect, (B2206-00 and B222C-00) etc.
I’ve tried:
1) Disconnecting battery
2) Removing fuse
3) Parking outdoors overnight
4) Reset to default settings
I’m at a loss! Any guidance???
Thank you in advance!
SitKneelBend
St. Louis
3.6 Pentastar
Upgraded to:
I’ve tried:
2) Removing fuse
Is this from a 5th gen truck and not a Classic? If so, I'd imagine that is where your issues stem from and this would be a UAV radio.
TwoGoatsOneRam
USA
Hemi 5.7 V8
I’m guessing 5th gen based on grill style from the VIN lookup. My only cause for hope is that I did not have the configuration or mounting issues that everyone seemed to need to modify in the other thread. Ie, the screen mounted perfectly, the UConnect radio I installed did not appear to have any un-used ports after I installed it.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Yep. common/known issues with the 5th Gen radios. Get a compatible 4th Gen radio
Post # 3881 - Good Info on 4th Gen Ram Panasonic 4c Internal Hardware PNs vs Mopar PNs
TwoGoatsOneRam
USA
Hemi 5.7 V8
Thanks all. Anyone out there selling a UAQ/UAS?? Looks like I now have an 8.4 UAV for sale…
DripJust
Canada Ontario
Adding Some Notes here ....
---- UAQ/UAS 4c Upgrade /BuCam issue on Manual Trans G56 trucks ----
------------ Panasonic 4th Gen 4C Delamination notes ------
Get a new (LA084X01 SL03) Screen/Digitizer assembly (definitely not an SL01 version… SL02 maybe) ~ $400 -$500 and replace it yourself
…. Or send it off to United Radio (Peachtree GA) recommendedor NavRepair (FL)
DavicArm_0 (C&H Car Stereo)
is reputable << VIDEO >> How to Fix Delaminating OR Bubbles 8.4" U-connect VP3 VP4 LCD MONITOR Touch-Screen Radio Navigation
Reference’s to help
>> @SitKneelBend is a great resource for help replacing the screen and gave me pointers. I donated my old screen to him to play with trying different ways to repair it. If you can, please do the same.
How To: Install a 2018 4C (UAQ/UAS) Radio POST 3051
>> He recommends replacing the original Thermal Pads while you’re in there, I did (Arctic Thermal Pad 145 x 145 x 1.5 mm - Silicone Based Thermal Pad).
>>> Some of my posts 8.4 Uconnect touch screen delaminating Post 209 and Post 223 -232 about it.
Also recommend this...
Amazon.com: 2X BROTECT Matte Screen Protector for Uconnect 8.4 (Ram 1500/2500 / 3500 / Chassis Cab), Matte, Anti-Glare, Anti-Scratch: GPS & Navigation
www.amazon.com
Other Info
RamForum - UAQ/UAS Digitizer Replacement Steps
YouTube - 2017 2018 HOW TO REPLACE Replacement 8.4" Uconnect 4C UAQ LCD MONITOR Touch-Screen Radio Navigation
You Tube – (Factory Radio Parts) - How to disassemble and repair the Uconnect 4 & 4C 8.4 Inch Touchscreen UAS & UAQ Panasonic Radio
Does anyone know if it's possible to switch from a early style gen 4 bezel and u connect with nav to the layer gen 4 style bezel and 8.4" UAS u connect ?
Administrator
Unfortunately the communication protocols are different from the 2009-2012 trucks and the +2013 trucks and the factory radios are incompatible.
Evil Phoenix
Chicagoland
I came to this forum because I have a very stock 2017 Dodge Ram 1500 Crew Cab Big Horn. I have been looking in to CarPlay for the old girl for a while. I started reading through this long thread and it became clear to me that there are a lot of variables with sourcing reputable radios. I went to M2Mods and filled out his contact form with my questions. @Mpgrimm2 reached out to me, we talked about it and he was able to set me up with everything I needed. He is very nice, very knowledgeable, very patient and helped me out tremendously. I paid the man and I expect my delivery soon. I will report back to you with my results after the install.
Just wanted to give more reinforcement to something that everyone here knows, @Mpgrimm2 is amazing and deserves a raise!
Thank you,
Evil Phoenix
Chicagoland
Just wanted to follow up with the installation on my 2017 Big Horn Crew Cab. I finished it in about 30 or so minutes in the driveway. I followed a stupid video that told me to remove the chrome trim ring around the center console and it broke off every tab but that's something else altogether.
I received all my parts from @Mpgrimm2 and even called him part the way through the installation.
When I initially hooked everything up it fired up like it should but didn't get any volume control or heater control from the radio or anything else. I was not alarmed because I was told that it could take 30min to 24 hrs. Because I was excited I went back outside every 30-45 min and after about 2.5 hrs it was perfectly alive!!!
I will say that I am super happy with the installation of the radio. The new radio is far brighter and crisper. It has HD radio along with CarPlay. It appears that every function, every soft button, everything is working perfectly.
I love CarPlay and have it in all of my other vehicles including my Road Glide, Trans Am and Work Car so not having it in my truck was frustrating.... Not anymore!
Beware of random radios and listen to everythign that @Mpgrimm2 says! He is very helpful and he made this a reality for me.
MANY THANKS!!!
Leland331
Sask
Hey,
I just installed a UAQ in my 2014. Install wise, all went as expected. But those of you with the alpine system, have you noticed a significant drop in audio quality over the RA4? I have read a few posts that said there were some differences but the sound quality on mine (any source, Bluetooth, CarPlay over usb) is absolutely atrocious.
I know the alpine system isn’t amazing by any stretch, but in comparison to the Harman unit, now with the UAQ I have to lower the bass as much as possible, crank the midrange, and the treble is very sibilant regardless of the setting (for reference I measured the response with a calibrated microphone). All I can say is that I almost want to take the UAQ back out and put something else in.
I have tried to do a few checks. All speakers work, balance and fade work, I’ve checked that the truck proxi aligned and sent the eq curve from the bcm to the radio. I am on update
CANADA-ASO-8.4-JR-34.2.0-20200123-JOM2
Just curious what the general consensus is on how these sound?
SitKneelBend
St. Louis
3.6 Pentastar
Hey,
Sometimes, the firmware just has bad sound quality. I have 39.6 for your radio if you'd like to try and flash it?
