How to remove passenger dash vent
Tanksjeep
Az
6.7 TD
Does anyone know how to remove the passenger side dash vent? The fins that direct the air left and right have come out of the arm that is controlled by the thumb wheel.
Ryan J
Oklahoma
2012 Laramie limited
You should be able to pop the little trim piece off but not sure if thays enough to help. May have to pull the dash off or maybe pull glove box out.
T
Tanksjeep
Az
6.7 TD
That’s what I’m thinking but I don’t want risk scratching it unless that is the only way. I’ll look at little closer at pulling the glove box.
stimpy433
IOWA
Here ya go, I just googled it!!!!
Cumminsforyou
USA
Same issue here, can see the vent from behind glove box but it looks to be heat pressed in, how to replace?
