CAGEYAR
- Joined
- Jan 17, 2022
- Posts
- 105
- Reaction score
- 151
- Location
- Stockton, NJ
- Ram Year
- 2017
- Engine
- 5.7L HEMI
Again I appreciate it but your the third one to post that, that method doesn't seem to be working for mePage from a 2009 owner's manual:
Are you pushing the skinny pedal into the carpet fairly hard,maybe you aren't pushing the gas pedal far enough down,or quick enough, if you have the key in the right postion.You have to do the pedal push to the floor and back up 3 times with-in 10 seconds.That's all i gotAgain I appreciate it but your the third one to post that, that method doesn't seem to be working for me
Yeah I’ve had the same thoughts and tried it many times with slower/faster and more or less distance between pushes. It’s just messed upAre you pushing the skinny pedal into the carpet fairly hard,maybe you aren't pushing the gas pedal far enough down,or quick enough, if you have the key in the right postion.You have to do the pedal push to the floor and back up 3 times with-in 10 seconds.That's all i got
Not to my knowledge, it's bone stock.Does your truck have a pedal commander on it or some other device hooked into the gas pedal?
Since you have some sort of diagnostic tool, I would recommending doing a scan for faults. My initial suspicion is you may have lost communication to either the accelerator pedal module or the cluster.Not to my knowledge, it's bone stock.
I haven't found any related settings on alfaobd but I'm still learning how that works
Mine just resets automatically when I get an oil change.Stupidest of all questions I know lol… but i can’t figure out how to reset the oil change reminder on my 09 1500. I did an oil change when I bought it but can’t figure out how to get rid of the pop up reminder thing, YouTube said to press the gas pedal 3 times in accessory mode and then start, another said to press it 5 times, neither worked.
I don't believe this will work on a 2018, it's more electronic on those, have to go through some menus in the dash I think. Check your owners manual or look it up if you don't have one.Will have to try this, as I have been getting the "Oil change required" notice for the past few days and I last had the oil in my 2018 changed 2,100 miles ago -- just before Thanksgiving. Dip stick shows full and clean.
