Boosted Motorsports
- Nov 2, 2011
- 467
- 423
- 2014
- 5.7 Hemi
Doing this today.
Well it did NOT go like his video. Put everything in just like he did, installed it into the truck and the dome light stayed on door open or closed and my front map lights wouldn’t turn on. Took everything back out and tested the 3 wires from the dome light plug on the truck. Middle yellow wire and black wire were the wires I used. I reinstalled the dome light with the leds and just hard wired the red/black from the leds to the yellow/black wires on the factory dome light plug. All is well and bright now.
Yes sir. Everything works. Plugged in the factory dome light and hard wired the led panels.Cool thanks for the heads up. I was wondering about John's install because he said in the video that he killed the voltage regulator/limiter and then did the install that way. SO you just bypassed the board all together? Does the push button switch still work as intended when wired like you did?
Cool thanks!Yes sir. Everything works. Plugged in the factory dome light and hard wired the led panels.
This weekend I will be doing this install. Why are you going to re-do yours, John? Having problems with it?Yeah I would poke around with a test light and find a different power source like mentioned but where I pulled power from seemed to work. I'm probably going to do a followup video and connect it to a different power source on the circuit board here soon. If you connect it directly to the power wires for the dome light then you lose the switch functionality so power has to be taken from the board after the switch
I have the center over head in the express. Would I be able to do this to that light as well.
I got this for the overhead dome light in my express. Works great, just a bulb swap.I have the center over head in the express. Would I be able to do this to that light as well.
