Hub Rings
BIGBLACKHEMI
Jersey
Ok so I finally ordered a set of wheels I went with a set of VCT Abruzzi's in 24's So I asked about hub rings the guy said trucks usually don't need them.. Is this true?? I'm not trying to have any vibrations
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
My Fuel wheels came with plastic hub rings, I would assume if they don't come with them they aren't needed. Hope this helps.
BlownGP
Houston/Baton Rouge
It depends on how big the bore of the wheels are.
A alot of street rims they make in our bolt pattern have the hubs the same size as stock. Since un-like other bolt patterns. There's not many other vehicles that use the same bolt pattern.
It aint going to hurt to have them though if you need them, there only $15 or so.
stevenmicheal
