Hurricane Crate Engines
W
Meh, lets not get carried away
But. Dollar for dollar, the LS is the beat swap engine
You know, if all you care for is horsepower
Dollar for dollar they are better,but horsepower to cubic inches the Hemi will make more power,it has noticably better heads then GM's heads
diymirage
If there was half the aftermarket support for the hemi as there is for the LS, the hemi would be a real contender
But partly because of mopars lack of support, the hemi is simply too expensive for hobbyist
Specially if you can get a junkyard LS and run it
W
Holdener made 1100 out of a junkyard 5.7 with nothing more then gapped rings and a big turbo,stock bottem end 5.7 ,lol .The cost differances between turbo'ing a hemi and a LS aren't that much if you have the capability of fabbing up the piping.
Marshall
Sk, Canada
2014 sport
We had a 318 poly in our old 3 ton Fargo grain truck,and by no stretch was it a "sexy" or even a good looking engine,even if it had those valve covers,lol. Nothing beats a Big Block Chevy for "sexiness" under the hood :Big Laugh:
you're forgetting the old wide block Hemi?
had one in a 59 Fargo 4 ton grain truck, and a step side 58 1/2 ton. and a 440 in a 57 short box.
Brother still has that.
Not a chev guy , but what really pulled nice was the 292?? straight six chev in trucks.
But as usual, getting side tracked again.
These new one sound interesting, never been around any
W
The Hemi has always been a wide block,i think you're referring to the old poly head 318,it was the one generally referred to as a wide block and was known as the "A" engine,which was later replaced by the smallblock LA engine
Marshall
Sk, Canada
2014 sport
had a 303 motor in a 58 truck as well, looked like the 313,318 Seemed to be a US made motor.
It needed ring job, but never got around it only one I ever came across.
W
The 303 if i remember right was a poly head engine,very similiar to the more common 318 poly head engine.It wasn't a Hemi as such,but was generally referred to as a "wide block"
Marshall
Sk, Canada
2014 sport
yes , I did not mean it was a hemi, just a 2 barrel truck motor, looked the same as the 318, same heads, v covers. At one time I had a line of those trucks behind the barn, with a couple Imperials or 3?
BTW there was 272 ? block as well , with hemi heads, in a 53 or 54 Desoto .
Same block as the 303-318. The "58 4 ton was 345 I think, been a few years.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
The Desoto "Fire Dome" hemi. The 1st of the breed
Easy to tell the early hemis (33*, 354 and 392) had dizzy in back, later 426 had it in the front.
The 272/318/360 family were all basically the same "LA" small block. (non hemi)
2012RAM1500RT
NC
Don't forget about the best "LA" small block, the "baby hemi" 340!
04fxdwgi
2016 1500 Sport
Forgot to list the 340 LA (which, like the rest of the LA's, was a wedge, not a hemi). My bad as I has a 340 six pack.
Forgot about the Red Rams engines:
First Generation Hemi (1951-1958)​
Hemi knowledge gained during and post-WWII hit the street in 1951 with the production of Chrysler’s first overhead-valve V-8, replacing the flat head (which had its valves in the cylinder block). The cast-iron, 331ci “FirePower” engine was rated at 180 hp.
Some of Chrysler’s divisions created their own dissimilar inline-six and V-8 Hemi versions, although Plymouth did not incorporate a first-generation Hemi into its lineup.
Chrysler and Imperial: FirePower (331, 354, 392 ci)
Desoto: Fire Dome (276, 291, 330, 341, 345 ci)
Dodge: Red Ram (241, 270, 315, 325 ci), Power Giant (354 ci), intended for heavy trucks.
2012RAM1500RT
NC
Yes sir. I, them, they, we just nicknamed the 340 "baby hemi" because of how it performed.
HemiLonestar
MD
Had a 292 MerCruiser in my old Crestliner. That thing was nice and torquey and replaced the original 250 nicely but I had to build a custom cover to clear it since it is a raised block.
Mostly; the 360 was an oddball. Everything top end was swappable but the mains were larger and the cranks were externally balanced (all previous LA were internally balanced) and a longer stroke. 273-318-340 all had the same stroke. 340 just a nice large bore.
Baby 440 would be more accurate. Same CR & cam timing as the 440 Magnum those years (basically 68-71, after that both engines were neutered) with a nice revvable short stroke.
W
Some 318's in School Buses and 3 Ton farm trucks even came through with a forged crank.
