HVAC and Radio switches not working
Warmage
My a/c and radio switchs are not working no light and they dont do anything
Only hazard button works
I can control radio and a/c from uconnect with no issues
Where is the fuse location for this controls?
W
Warmage
Any info would help, i checked every HVAC fuse in the fuse box all good
Its Ram 1500 2013 5.7L
Administrator
have you pulled the center dash bezel off and checked the plugs haven't come loose?
W
Warmage
No not yet, that would be strange
Burla
2010 Hemi Reg Cab 4x4
TIPM is one suspect for sure, you can run a bypass to check it. Google bypass TIPM and use a relay not needed like cig lighter. But if so weird you can access through u connect.
W
Warmage
Whats TIPM?
Burla
I wonder if part of the ignition switch isn't working? puzzler for sure, stumped me.
TIPM is a FCA relay/fuse box. The issue is when they go out it usually is the solder joints inside TIPM and not a blown relay. Kinda of a silly way to do a fuse box if you ask me, they did away with it in later years.
W
Warmage
I checked under bezel all connection are good.
If tipm is the problem its replacable, as the harness connects to it from under.
But im sure im missing a fuse somewhere
I checked under steering dash nothing to be seen.
I saw additional fusr box on the web, but not sure about location.
Attached photo
W
Warmage
i still didnt manage to fix this :(
Tc3509
Canada
I cant find those fuses either
turkeybird56
Central Texas
If you say all fuses good, and U R able to control the functions from U-connect, then I doubt a fuse issue, more like a wire short/disconnect. U may have to trace wires back and using either and ohm meter or 12V tester, see if U can find short. My thought is: if options working but not the knobs, gotta be a wire/junction not plugged in going to the dash. BUT I could be 100% wrong. GL on finding the issue, sorry no real help here, I just remember there are like 5 modules plug into that ring just not sure what goes where. U could pull the cover, start truck, and using a tester see if U R even getting power to the wires that go to the 2 knobs, only thought I have.
ADDED: If U had the additional short fuse box, gotta be somewhere near the TIPM (fuse box), or wired off one of the main fuse lines at the end of the box with a heavy gauge wire to handle voltage going from it. A lot of PPL who run a lot of extra stuff put in auxiliary fuse boxes running off a main power lead and wire all their stuff into the auxiliary fuse block.
All above IMHO...................
Shiva
Fairport
There is a single inline mini fuse all by itself on a small harness pretty much right beside the brake booster.
Follow the wires leading from the negative battery post about 6 to 8 inches. It is under a flip up cap and is yellow.
When a mechanic pulled that fuse to shut down my failed update radio I lost my a/c as well.
It is the yellow line in this pic
W
Warmage
i found this on other search the fuse is ok and for me, it powers the display only
so if you remove it the display will turn off
so now im on the process to by new switch panel and/or the A/C module that is in the dash at passenger side door
W
Warmage
i replaced the switch panel with a used one and now i got all my controls back !
i have no idea why would the stock one fail very sad
marc cormier
qc, canada
pentastar
you should try to disconnect the battery for a few minute, with all the electronic you'll be surprised how many trouble it can solved.
