I found a way to receive your own PIN CODE without the dealer :)
SeppW
Northern VA
Hemi 6.4L
Worked for me on '16 2500 Tradesman Power Wagon.
Flammable_Solid
Mesa, AZ
Don't go to the service department for the PIN since they have to go to the parts department. Go straight to the parts department. Bring your registration and drivers license. Tell them you want your RF Hub PIN not the key code PIN. If they ask why you want it tell them because it is information about your truck that you are entitled to receive.
Just back from the dealer. They had no idea what the RF Hub PIN was. I have the key code now and and ignition code.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Confirmed the AlphaOBD method worked on my 2017 Ram 1500 Sport down here in Australia. Awesome stuff
Worked on my 2017 and my 2013.
yomanne
Cedar Falls, IA
So I used the OBDLink MX OBD2 reader and downloaded an app called Pin Puller.
It says it need elm237 pr something but when you connect using Blietooth it says its using the MX like an ELM!! From this point you than click on the model vehcile you have and purchase some points. For pin code its 50 points and costs $19.99. After that cost start. It asks you to put your 4 way emergency lights on and the n click continue. Moments layer it shows VIN and your pin code!
Hope this helps others with reluctant dealers!!
You can also get the 4-digit keyfob pin using alphaobd by connecting to the "Radio Frequency Hub" and choosing "Read PIN".
DonAlex1053
USA
EcoDiesel
I have an OBDLink MX+, bypass cable and alfaobd. I've been trying to read my pin for a few days now but every time I press the start button nothing happens.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
I'm in the same boat. Going to be installing OEM remote start and need the code but every time I hit read pin in the RFH section it just sits and nothing happens. Is there a long wait time for it to do its thing? I don't get an error or anything maybe I just need to be more patient lol.
DonAlex1053
USA
EcoDiesel
I think my issue is that I'm using the security bypass cable from my SFT tuner. Its an AEV security bypass cable. I'm pretty sure it doesn't bypass the SGW in the hub. Later today I will trying again with a new cable.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
I went to the dealer today and they gave me the pin no questions asked. Took about 10 minutes.
Sking80
Atlanta Ga
Any luck on getting it to work. Mines does nothing. I’m just waiting and waiting ver 2.2.5.0
