I just purchased a 2019 3500 6.7L. Check engine light on for codes p0401. I cannot find a MAP sensor to replace the old. Possible EGR valve?
kapster411
Ohio
6.7 cummins
Just purchased a 2019 ram 3500 6.7 cummins. 140k miles. CEL is on saying I need a map sensor. Cant find one. Cleaned the eg r valve and MAP sensor. Is the MAP sensor on the throttle body below the egr? How do you know if the eg r is working correctly? Can I continue to haul my 5th wheel with a bad eg r or map sensor? HELP
