I learned something important today.
PCA4208
Albuquerque, New Mexico
Now I'll start off saying that it was not on my 2003, but on the 79' power wagon. But I knew that nobody looks in the 1st gen section so here it goes. While putting long tubes on the trusty 360 I ran into a problem with the manifold stud. So, I pulled it off by heating it and soaking in acetone ATF mix. ( which really does work GREAT) Stud then comes loose so I start unscrewing. Little did I know that on these LA engines, the stud plugs a hole in the cooling jacket. SO out comes the stud AND a couple quarts of coolant all over everything. In short, I learned to never remove manifold studs, and that I hate anything to do with exhaust, except the sound haha.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Not all manifold bolts go into the water jacket, so it'***** or miss unless you specifically know the engine. Believe there is a current thread someplace here about a fellow waiting for the dealer to replace a head they drilled into the jacket trying to remove a broken manifold bolt on a hemi. It happens....
PCA4208
PCA4208
Yep. Well now I have to have that experience again, because I have to replace the exhaust gaskets. :(
PCA4208
PCA4208
Ya I guess so. Also on the bright side all my neighbors hate me for revving the open headers truck everyday haha.
chuck
Maryland
2013 True Blue Big Horn
lol that's always a plus!
Sent from my iPhone using Tapatalk 2
Redtruck-VA
Virginia
Give'm hell...
PCA4208
PCA4208
Haha why not! Besides I'm sure they already do from me going to football at 730 each morning. In my 2003, but still loud haha.
HemiLonestar
Navy Badge Coast Guard
MD
The LA's are like that, so are the B/RB's (on the exhaust, luckily the intake is a dry manifold) if I remember right (been about 15 years since I put a set of headers on a big block).
Redtruck-VA
Virginia
Haha I just noticed you're 16 years old. I got grand children older than you. Sounds like you have good mechanical skills, well done.
HolyRamBatman
Deep in the Heart of Texas
No bueno! On the bright side... at least you learnt an extremely difficult way to drain your coolant! :naughty:
First laugh of the day....Thanks Steven
That has popped up on the Power Block series on Spike. Never ran into it personally but is good to know. I can imagine what was going through your mind when water started coming out. WTF?? AWWWW:dancingpoop:
PCA4208
PCA4208
Haha yeah I freaked out. Then I used 3 funnels to direct the fluid into a bucket. But yeah, I'd say I have good mechanical skills. I just retrofitted an HEI ignition unit into the truck. I plan to pull the engine and put in a cam and port the heads in late July/ early August. Then get the block milled to raise compression, it should sit around 320 Hp/ 380 torque if I'm lucky haha.
Redtruck-VA
Virginia
Ahhh yes, we must educate the young when we can.... mill the heads, deck the block. HEI conversion sounds like quite a trick.. good for you.
PCA4208
PCA4208
Thanks. And yeah the HEI works great. I did away with the crappy original electronic ignition and ballast resistor. So now I have full 12v to the system and a good enough module to support up to at least 6k rpm, but I doubt this old thing will ever get up there. And yes I did buy a new ignition coil that can handle full voltage.
PCA4208
PCA4208
This is how I did it.
stevenmicheal
