I need help please
beebop
Touch them together for maybe 10 seconds, then just leave the battery disconnected for half an hour. Then connect the battery and see what lights are on, if there's no change then you have an active fault and need to get the codes retrieved.
Does the truck start and drive?
THANK YOU Tach_tech, I cured my airbag warning light with your disconnect the battery cables, discharge the modules trick. Thanks again to You, and to the Forum. :):)
stevenmicheal
