I NEED HELP!
dahlgrendustin
Pennsylvania
6.7 cummins
I brought my 2014 6.7 cummins into the shop for it not running. The shop says the entire exhaust system, all the way to the exhaust manifold is clogged. What do I do?! They are saying it'll cost 21g to fix! Could I just delete it?
jws123
nj
As mentiond above 21g is HILARIOUS. Pull that crap apart yourself or go to another shop PA has a lot of terrible mechanics/shops depends on where aswell but i wish you luck.
D
dahlgrendustin
Pennsylvania
6.7 cummins
Thank you everyone for your input. Currently paying them 1g to put it all back together so I can grab the truck.
I've wanted to fully delete it since I bought it. Given I was a 91M I think it'll be light work. But I want to if it'll work with a tune instead of replacing all the emissions ********.
jws123
nj
I would leave it apart and tow it so you dont have to take it apart again lol.
jws123
nj
isnt that hard to do in your state?
pscarbor
Many, LA
5.9, 5.7 Hemi, 5.7 Hemi
Just curious, clogged from what? I just watched Beverly Hills Cop, did you check for bananas? :)
Neomoritate
Chicago, IL, USA
Shop is lying.
Literally not possible for the whole exhaust system to clog, and even if it was possible, 90% of the system is open pipes you could clean out with a stick and a brush. It's most likely that the Diesel Particulate Filter is clogged, that will completely plug the exhaust, stopping the engine from running. IDK if a clogged DPF can be cleaned out (I'm sure someone here can tell you if/how), but a new one (Mopar 68417517AB) looks like about $1,800 from Mopar, and it shouldn't take more than two hours for a muffler shop to install. There may be other sensors/misc. parts and programming.
For $21,000 that exhaust better come with a new engine.
nlambert182
Huntsville, AL
Maybe they added in an extra 0. Dunno if you can get away with a delete in PA, so you may be better off replacing the DPF. You can do it in the driveway in about an hour. Both cost about the same amount, but the DPF swap is much easier mechanically.
Sur5er
NY
I'd ask to see the labor rate they are using. $1K is about right if the hourly rate is $750! Towing to ANY shop would be cheaper! OR, run it "Commando"!
slbenz600
La Verkin
6.4 L
That Dealership is going to excuse the language they are going to screw you without vasoline. I say that from a similar problem and was told to take to the local dealer that someone figured couple of hundered bucks. The dealer wanted to install new Radiatoor, breaks, rotors, and on for just shy of $10,000. I picked my truck up and found an independent that work for Ram my bill was $100 dollars.
NCRaineman
NC
2019 1500 Classic
Unless the truck absolutely lives for towing I wouldn't have a modern diesel. All the emissions crap the govt has mandated over the last 20 years has absolutely ruined their simplicity and reliability. I work in logistics and we lease new trucks from Penske every three years but it is still problem, problem, problem.
nlambert182
Huntsville, AL
The emissions equipment is easy to replace. It's a problem, for sure, but none of it is difficult if you have any mechanical knowledge and a few basic hand tools.
D
dahlgrendustin
Pennsylvania
6.7 cummins
I'm a cert diesel tech and was a 91m in the US army. I'm more concerned about the ecm part. What would happen if i just get a delete kit with tuner. Would thay work?!
D
dahlgrendustin
Pennsylvania
6.7 cummins
Pa doesn't have emissions testing as to my knowledge but I could be wrong. I'm looking at the delete for the added reliability and power for towing. Its my landscape truck. Frequently hauls 20k and up
mdc1990zr1
Conshohocken, PA
Correct, my PA registered diesel does not get an emissions test, but the gassers do get tested
stevenmicheal
