bm02tj
The stone wall is FCA says see your dealer and the dealer says it works as FCA designed
but no one will address the issue and after the general manager of the dealership tried it on his truck
he agreed it is not right but needs the large customer base south of the border to complain as we are
a small part of the pie @RamCares
In second gear screaming at 4700 RPM (Not good for a cold motor) on a warmer day will all of a sudden try
to put you through the windshield when the throttle comes off
If the road is wet snowy or icy you will loose it
I comes down to the programmer does not know because no one will tell them so they can fix
which should be a simple thing IE no gas by driver and over 2500 RPM shut the fuel off easy
