ignition
Jp44
georgia
4.7 semi hemi
replacing coil packs, plugs, and wiring. 3rd gen 1500, 4.7. looking for harness type wiring that connects to packs, but having a pretty hard time.
jws123
nj
Whats wong with the plugs going to your coils? If the wires are messed up thats one thing but if its just the clip there are ways to hold the plug on.
J
Jp44
georgia
4.7 semi hemi
Just old, I'm having problems with misfire. replacing coils, connections, plugs etc. might not need to replace all of it but I am.
Daw14
Have you looked for any codes ?
jws123
nj
Coil plugs are not like spark plug wires they dont rly go bad like mentioned above did you scan the truck? what cylinder is missfiring? 4.7s are known to missfire for many reasons coil,plugs,rocker arm fell off,timing jump if the guides where never done ect would be a good idea to run a compression check to.
J
Jp44
georgia
4.7 semi hemi
they may not be the problem, just replacing them along with other parts.
therapywolf
