rlampman
Has anyone replaced the polyurethane bushings in the Inez Hotrod front control arm with an OEM style rubber bushing? I'm thinking it may help with the harshness on ruff roads. I have a squeak now and am thinking of disassembling and greasing the bushings. As long as I have it all apart it would be a good time to do this.
Also, does anyone know the exact dimensions of the bushings so I can look for a bushing before I take it apart. Better yet a part number if you have done this! I have a 2012 2wd RC
I know the polyurethane will last longer and is stiffer for better performance but I just want a smooth daily driver. I don't need the performance and would rather have a softer ride.
What do you think?
Rod
What do you think?
Rod
