Mike Townsend
I talked to a shop local to me about putting the 4/6 drop on my 2014 RCSWB. They said they would have to cut my frame which I didn't think that was necessary. Can someone tell me if they are right or not?
As indicated, by 1Sloram you cut the upper control arm brackets off the rear diff and you remove the bump stops from the rear frame. You do not in any way cut the frame.I talked to a shop local to me about putting the 4/6 drop on my 2014 RCSWB. They said they would have to cut my frame which I didn't think that was necessary. Can someone tell me if they are right or not?
