Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Discussion in '4th Gen DIY' started by Mpgrimm2, Sep 20, 2015.
  1. 18harvest
    18harvest Senior Member
    47
    306
    129
    Mar 15, 2019
    huntsville
    Ram Year:
    Engine:
    I am running 30.24 on a uas but there is no going back to 22.6. i don't know about 22.61 I would be quessing no.if everything is working I would do like set kneel bend suggested and leave it.it seems the problem is the in the over the air process not necessarily the update file itself i.e. manual update.i would like to have a 32.4 uas file.i have access to a uaq one.
    SitKneelBend likes this.
  2. 48PowerWagon
    48PowerWagon Senior Member Military
    59
    176
    165
    Nov 22, 2019
    Bellingham, WA
    Ram Year:
    Engine:
    I've had it for some time I got it from on of my IT Peer's FTP (We IT Guys collect and share various uumm "things") I would lave a Copy of the UAQ 32.4 if only just to store it
    Oh additionally I'm looking for the map update packages for manual updates past 2018
  3. 18harvest
    47
    306
    129
    Mar 15, 2019
    huntsville
    Ram Year:
    Engine:
    Search under additional uaq uas files and a thread will pull up.however when I installed the uaq 34.2 file it didn't have a map pack attached so when it was put on the radio nav didn't work so I added one from aNother file and it worked.so a use at own risk thing.
  4. SitKneelBend
    SitKneelBend Senior Member
    7,094
    3,305
    Jan 8, 2015
    St. Louis
    Ram Year:
    Engine:
    3.6 Pentastar
    Found this setting that works (2018 UAQ). It didn't cure the notification volume reverting to 15 every time but it did turn off the loudness "effect"...
    [​IMG]
    Has anyone successfully cured the loud notifications on these?
  5. 18harvest
    47
    306
    129
    Mar 15, 2019
    huntsville
    Ram Year:
    Engine:
    I get messed up anyone have a uas 34.2. File.of course I have a 32.4 that's what I am running.i would like to put my radio back to what it came with.
  6. chrisbh17
    chrisbh17 Senior Member
    6,604
    7,261
    Oct 12, 2017
    Ram Year:
    Engine:
    Is there a site to download updates for the UAx line of radios? Or is it OTA only?
    If they let people download it I might be able to figure out the pattern again....but IIRC UAx files were not attached to the original UConnect download site.
    Mpgrimm2 and SitKneelBend like this.
  7. SitKneelBend
    7,094
    3,305
    Jan 8, 2015
    St. Louis
    Ram Year:
    Engine:
    3.6 Pentastar
    @Mpgrimm2 might know, he has a UAx and connections.
  8. cj22944
    cj22944 Member
    46
    34
    Jan 18, 2021
    CA
    Ram Year:
    Engine:
    I've tried to do this on my ram but can't find this option. What year are u accessing to do this?
    Sent from my SM-G981W using Tapatalk
  9. Mpgrimm2
    Mpgrimm2 Senior Member Preferred Vendor Military
    5,311
    3,471
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    2019 Laramie QC (5th Gen)
    Engine:
    5.7L eTorque
Share This Page
