Inside Overhead Console lights Failing
etbrown4
My 2016 has had the overhead lights fail 3 times. First two, FCA replaced the complete units. Now I have one light on one off, though often when they worked they were weak or dim. (yes I know I could have a bulb out)
I've read it could be:
Bulbs
Bad switches
Bad wires
Other than bulbs, I'm interested to learn the most common diagnosis, and solution.
If it was bulbs, I doubt FCA would have replaced everything!
Must have affected many owners.
Administrator
Sounds like you have the factory LED overhead lights, this post may help:
E
etbrown4
I've got Led interior lights around and l leds in the bed, so must have Led package.
It's a bit confusing because your linked article talks about a 194 led bulb.
How do you determine if you have a plug in Led bulb, or if you need the 6 led panel.
Seems that if it is the 194 led bulb, there's no need to take down the console.
E
etbrown4
I'm sure I have Leds in overhead console. Unlike several videos showing plug in regular 194 bulbs or some plug in 194 Led bulbs, I have neither.
What's there is a small square flush led panel of maybe 10 tiny Leds, but nothing to plug in or unplug.
Any videos for replacing this type?
E
etbrown4
This video has the 194 removable bulb.
My 2016 had the factory Led package originally, so no 194 removable bulbs.
Anyone know how to replace factory Leds?
