Install dash cam
Lysek85
Burbank il
Hi I have 2022 ram 1500 I want to install dash cam but for the power I want to use one of the fuses which one should I use or are there I empty fuses I can use?
Use a t-tap like this: RED WOLF 12 Volt Power Adapter Wiring Harness Switch Connector Plug w/Fuse for Chrysler Dodge Ram 2001-2021 Power Outlet to Add Backup Camera CB Radio Radar Detectors Portable GPS https://a.co/d/8sOy2qD
It probably fits a '22 also, but it wouldn't hurt to double check
Mb7640
Fountian hills az
In my 2021 I used a fuse tap. Just be sure to use a fuse that is in when the truck is running. Like outlet plug, fuel pump. Climate control. Stuff like that.
bm02tj
B C Canada
If you pick an accessory tap it can cause it to be confused with on then off a start
I had this happen when I was using the lighter plugin with adapter
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
I just ran the wire around and under the dash and plugged it into a USB power point so I could leave it on while parked if I want. This truck has so many USB's, I have plenty to spare.
JW2 Innovations
Supporting Vendor
Sparta, TN
2016 Ram 2500
I saw an adapter cable that taps into a mirror plug somewhere....anyone seen that?
Hammer22801
Louisiana
Razzman
Southern Arizona
2020 Limited CCSB
I used the SimpleUSBPort Dash Cam Power plug and it works flawless. I also used a short right angle USB cable to clean up the install and and minimize the exposed cable. Took all of 10 minutes to pop the cover and install.
Loudram
Navy Badge
South Jersey
Hemi 6.4L
What trailer camera do you have? Looks like the Haloview that I have.
Razzman
Southern Arizona
2020 Limited CCSB
It's the Amtifo 7" Wireless 1080P, for $139 i'm happy with how it performs. Been three years and about 15K miles and it's doing good so far.
RetirementRam
Army
Cincinnati, OH
2023 Limited Elite
Just took delivery of a new 2023 Ram 1500 Limited Elite with the fancy rear view mirror that can switch between regular auto dimming mirror and using rear facing camera instead of just the regular mirror. Hoping to find something like the Dongar wiring tap-in underneath the rear view mirror housing to power a dashcam to avoid running a bunch of wire. Does anyone know if such a dash cam adapter exists? I have seen dash cam adapters advertised but they specifically say for the auto dimming model only, not the one that uses the rearview mirror as a display for the rear facing camera.
Any help/advice would be appreciated.
d0c-
boston
2004 --> 2014 --> 2016 --> 2023
have you tried taking it apart to see what the power supply under that plastic fascia looks like?
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I just did this on my 24 2 days ago. Use the dingar dongle on amazon. Took me 30 min to install start to finish including running the cable for the rear camera.
