Intake
Hotroder383
Washington Mo
318 or 5.2 which ever you want
So I have the leaking kegger and would like to get rid of it instead of payin $120 for the part to fix it and an afternoon of work modin it in hopes of some performance gains. Prob is only see 1 intake listed for a replacement and its $600! Mopar Performance P5007398AB Mopar Performance Aluminum MPI Intake Manifolds I seen elsewhere a suggestion for a mopar M1 and found one on ebay for current bid of $130. Will this intake work with my obd1 pc or will I have to reflash it so as not to throw a code? Any other ideas suggestions?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
You might check with lifetimedoge, I believe he has used a few of those in his builds
MikesRammin
New Carlisle, Ohio
5.2 Magnum
It should just bolt on no problem. I've heard though if you have a stock engine you lose alot of your low end but gain in the mid to upper rpms
Hotroder383
Hotroder383
Washington Mo
Hmmm not an option for my truck, I actually want MORE torque, guess I'll stick with the stock keger and mod it some as seen in the DIY section. may be a dumb question but dose the 5.9 intake work on the 5.2? Like the chevy 5.0 and 5.7 or are they compleatly different?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
they are the same. the throttle bodies I believe are the same too
