schraxx
Hi All,
i own 2008 Ram QC 5.7L and currently do have a electrical problem with my interior lights.
I´m living in Germany and as you may can imagine, this type of car is not very common here - therefore it´s difficult find somebody with experience on that.
That´s why i was hoping you guys may have an advice on how/where to start the search for the issue.
The problem is the following.
My Interior lights (Map and Dome light) won´t turn on when any of the doors will be opened, nor wen i press the unlock on the keyfob (acc. to the owners manual they should do), nor when i dial the dimmer to the top position. However, i still can turn on the map lights manually by pressing.
It seems to me very unlikely that all four ajar switches and the dial wheel are broken, but more likely that there is some problem at the control module (TIPM??) or on the wiring from the module to the lights.
Does anyone have an idea how to find or at least further narrow down the problem?
BTW: The fuses are OK, this was the first thing i´ve checked.
Thank you in advance
