Aaron1180
Hey everyone I’m Aaron I recently purchased an 04 Ram 2500 with a 5.7 Hemi engine I am having some electrical issues with my dash lights and dome lights. All my dash lights with the exception of a few including check engine lights, lamp out, and door ajar and radio all work. However, everything else inside the truck stops working when you turn the key over. I have found if I replace the fuse when it’s running then all of the light work until i turn off and then turn my engine back on and the fuse is blown again. Is there anyone that has had this problem occur and found the short in the wires and if so where did you find it and what wire was it. Trying to find a place to start looking. Thank you for you time.
