keballard
- Feb 18, 2013
- 1
- 0
- 2013
- Hemi 5.7
I have been having an intermittant starting problem with my 2013 Ram 1500 Hemi. It has happened a half dozen times. When it occurs, I put the key into the ignition switch and switch to run, everything comes on the dash display, but I notice the shift lever indicator has turned yellow and I have a series of messages scrowl on the screen - Service Power Steering, Service Electronic Braking System, and Service Antilock Brake System. When I try to start truck nothing happens. I can wait sometimes a half hour or so and the truck starts fine. This morning for example, I went out and started my truck (no problems) and let it run for a few minutes then shut it off. I went out a half hour later and the truck would not start with the symptoms described above. Then a hour later, I was able to start the truck just fine. I noticed that the malfunction indicator and ESC activation/malfunction indicator lights are on. I checked the codes with my code reader and several came up - U110C, U1110, U1120, U1403, U110E, and U0140. Most of the codes lean to a faulty Body Control Module. The truck is still under warranty and have an appointment with Dodge next week. Just wondering if anyone out there has come across this with their truck. This issue first started this last summer and I took it in to dealer. They could not duplicate the problem, but said they found a few connectors that were loose (this was in late November 2021). The truck ran fine until last week when it started acting up again. I would appreciate any known fixes or anybody's input. I would like to be armed with a little knowledge before my appointment with dealer.
