Is anyone's oil NOT black immediately after an oil change?
1970Pelle
90 W150,ShortBed/87 Ramcharger 2WD project
W150 318,4bbl,auto4x4 VGC/ 87 Ramcharger 318/904 VGC
Its a by product of combustion. Your new engine oil is still brand new. The only issue is they dye in the oil has changed to black. From the above statement. You wanted a Cummings, here is a slight negative if you like. But it doesn't effect the function of your engine oil A diesel engine is dirty. Always have been and will always be a dirty running engine by design.
Or switch to alcohol, which means changing design. Look at tractor pulls, Most have gone away from diesel. Same tractors just different fuel.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Dye in the oil? Um, no, the only oil that is dyed is transmission oil - dyed red to visually differentiate oil leaks from engine oil leaks.
Blowby soot past piston rings makes oil black from the detergent/dispersant additive carrying it in solution so it doesn't plate out on engine parts. Soot is very abrasive.
Hoochiemama38DD
Toronto
Welcome to owning a Diesel. The dirtiest fossil fuel engine ever made. But it does have LOADS of low end torque.
Poram
seanclark1503
Seaview, Washington
6.7 Turbo Diesel
I’m thinking that you might want to change your CCV filter at your next oil change. I have done that with the 3 trucks that I’ve bought as soon as I get them home after purchase, (all were used with between 120k-150k miles. My oil was only black within the week when I didn’t change the CCV filter on the first one with the oil. Those filters are supposed to be done at a 60k mile interval… I’d never go more than a year / 20-25k without this service being done. It’s a difference maker for your oils longevity and that translates to the engine’s extended length of service prior to any need for major repairs.
seanclark1503
Seaview, Washington
6.7 Turbo Diesel
Obviously (or so I thought it was) , a diesel’s engine oil is going to turn black rather fast compared to that of a gasser (gasoline engine).
The question was,
Is anyone's oil NOT black immediately after an oil change?​
Now I thought that’s what I was babbling about. If you’re intimidated or not understanding what I am saying, you may need to be a bit more specific than, ‘WTF are you babbling about ?’ My response to your question and emoji along with the peanut gallery jumping on the bandwagon is , that’s your response and you’re a senior member ? I am definitely on the we wrong site . I thought everyone was here to help others with information, not to ridicule them. I can’t speak for the condition of any engine but my own , but it takes more than a few days and miles for my oil to blacken.
After an oil change my oil is not immediately turning black again. That’s what I was saying. SO , WTF R U BABBLING ?
I guess I’ll just read and let you say all the words
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Well, I don't see how the two could possibly be related (I'm talking 2 minutes of run time), but since I don't know if or when that filter has ever been changed, I'll go ahead and change it out.
06 Dodge
Forest Grove, Oregon
6.7L CTD
In the 12 years I owned my 06 5.9 CTD the oil would always be black with in a few minutes after start up of every one of my oil changes, as others have said black oil is just a fact of life in the 5.9 being it has egr factored into the valve timing...
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I accept that, but I would still like to know how that works exactly.
