Is there any 2WD Front Level ?
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
2014 SLT 2WD QC. Just want to level (lift) the front, but everything I see is only for 4x4 or lifting 4-6" all the way around. Are there any 2" front lift options for 2WD?
Jkieffer
I had rough country springs and billstiens put all the way around. I also had the put mevotech lower control arms on since I had a torn lower ball joint.
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
Are these the RC springs you got:
https://www.roughcountry.com/dodge-leveling-coils-9232.html
I also found these CST springs:
http://performancelifts.com/cst-2013-2018-ram-1500-2wd-coil-springs-csc-d3-3.html
So by putting on 2" front springs you got the torn ball joint? Or did that happen from something else?
Jkieffer
Happend when I paid someone to.do the work for me that didn't know how to do it.
Jkieffer
Yes those are the springs.
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
Getting ready to pull the trigger on front lift/level. Just worried that 2 inches isn't enough to get LEVEL. The reviews and posts say these work on 2WD, I've seen pictures that look ok...
But if I use a tape measure on MY truck, it's not adding up - my front fender is currently 3.5 inches lower than the rear, so how does a 2 inch taller spring get me level? Is my tape measure wrong?
Maxtrac Suspension
Anaheim, CA
4.7L V8
We offer 2"-2.5" lift coils w/ slightly longer front shocks. We also have 2" coil spacers. What engine is in your truck?
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
Went with the least expensive option, the 2" coil springs from Rough Country. Installed myself, which took me twice as long as replacing 16 spark plugs. Ended up with 2.5" of front lift on the truck. Ride is stiffer over speed bumps but seems better in corners and stopping. Next up 20" wheels, 33" tires, and alignment...
BEFORE
AFTER
MadMax32
New Jersey
I see kits for 2wd V-8 models. What about V-6 models? Would it make the front just a little bit higher?
Cesar592
3.6 pentastar
ok I just installed level kit on my ram 1500 slt 2013 but they tell me that I have to install some longer shock absorbers some help from someone with experience
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
If it's a 2WD and you just put in 2-3" springs or a spacer, then the original shocks are fine. Did you install the level kit yourself? WHO told you you need longer shocks?
Ratket
Arizona-
You could get “ shock bracket extensions”. If it is a concern , I’m not sure how much leway the factory shocks on the 2x trucks have.
norton333
My Rough Country level springs were done with the original shocks, no issues what so ever.
Cesar592
3.6 pentastar
I installed them a professional worker but on the outside he put me 2.5 level kit but he told me that before doing the alignment he recommended me to change my shock for a longer one to avoid problems in the future
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
Alignment numbers with 2.5" rough country and new 20x10 wheels with 35x12.5 tires:
Next steps:
-alfaOBD tire size change
-adjust the headlights
Matts175
My last Ram was a 2wd and I did 2.5" poly coil spacers up front. I had to get longer shocks. It rode like crap with the originals as they were almost out of down travel. What I ended up doing was buying a set of 2WD 2500 shocks. They mounted up the same and everything and were 2" longer. If you go on the shock manufacturers websites, they will show you the dimensions of the shock eyes and the compressed and extended lengths and what not. I put 180,000 miles on that truck with that set up with no problems.
tzr916
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
My last Ram was a 2wd and I did 2.5" poly coil spacers up front. I had to get longer shocks. It rode like crap with the originals as they were almost out of down travel....
Versus 2" level RC springs that are stiffer than the OEM springs, so they travel less than OEM. So I'm guessing that I'll never experience an "out of down travel" condition. But if I did, what would that feel like exactly / how would I know ?
