What do you guys think ?
Also keep in mind, these may mess up your TPMS, these are LT tires and they run at 55psi front and 45psi rear.
Air pressure in the tire is determined by tire size and weight of the vehicle. The fact that they are LT tires have nothing to do with the pressure ran in them and the TPMS alarm levels are set by vehicle, not the module in the rim.
Sorry, but that's simply not correct. My 2011 1500 weighs the same and has the same payload capacity as my 2016 1500. My 2011 runs the standard factory "P" tires and runs standard pressure. My 2016 1500 (Rebel) has factory "LT" tires and runs higher pressures, 55 and 45.
