Right on, the best news backed by science and the results on this board is that redline doesn't meet it's full tick killing potential until the oil has over 500 miles on it, keep us updated. As for what happens in the cold, that isn't lifter tick, it is piston slap, and that is when metal shrinks due to temp, no way around that one.
Now, some engines are more susceptible then others, that may help us understand lifter tick if we knew that those trucks that are prone to piston slap are also prone to lifter tick, but we don't know anything like that at this point. Maybe in the future we will test that, or poll that. For now, piston slap doesn't seam to be a large enough problem to get back good data.
Having said that, thanks to hemi395 we know with cold piston slap and redline that 0w30 is literally the only redline offering that helps that condition, which also is backed with science, as that oil has the most vii's then any redline 20 or 30 weight, so it makes sense just like the plating effect of heavy ep additives makes sense. The miracle is that these theories are actually working, they are fixing conditions that otherwise are unfixable. It has always been an age old question if oil choice matters, and most of BITOG will tell you it doesn't, and I was in the camp myself until the mass results we have gotten from ram forum.
