Its bogging down!!!
Tommie1
Howdy yall! I recently bought an 07 Ram. The other day I was on a slightly longer trip than normal. Maybe about 35 to 40 minutes. I stopped at a red-light and it died. I managed to get it started again and pulled into harbor freight parking lot. It wouldn't start and it seemed to get stick cranking over. I had to take the key completely out. It threw up the check engine light and the throttle body light. I disconnected the battery again and waited for a bit. After that it started up the engine light was still on. I took it to the movies and when I came out all the lights were off and it drove fine most of the way home. It bogged down when I pulled onto my road. Same thing happened today no warning lights but when I got home it lost acceleration and rpms dropped. Only did it for a few seconds and came back. The throttle body is clean as well as the MAF sensor. Not sure where to go from here
Burla
2010 Hemi Reg Cab 4x4
Step one run obd2 codes if you got a light. This is 5 gen ram as well, you need to go to 3rd gen.
stevenmicheal
