Joying 10.1 Android Car Stereo Information
steven4mcg
California
hemi 6.1
Do you have a source for all the options in settings? What does each one mean etc.?
permaculturemike
Massachusetts
3.6L V6
Been looking into upgrading the stock 5" radio in a 21 classic and sent joying an email asking about which unit would be a good option and if everything would work correctly with any of the newer units. This is the response they gave within 24 hrs, figured I'd drop it here to save someone the time:
Dear friend,
If you want to install our head unit, you also need to check this dash kit: https://www.ebay.com/itm/275259663946?epid=19005352187&hash=item4016c1264a:g:Fn0AAOSwlCBbf3sl
(The dash kit size need to be 178*100mm, you need to inquiire for the dash kit seller whether the kkit cna be fitted on your car)
If fitted, you can check this head unit: https://www.joyingauto.com/newest-u...0-0-car-stereo-with-hands-free-bluetooth.html
Sorry, we do not have the workable harness adpater for keeping your steering wheel control and your factory camera. you can check the harness adapter from other harness seller.
https://connects2.com/products/steering-wheel-control-interfaces/vehicle/Dodge/Ram (You can check this one for reference. but you need to inquire for the harness seller which harness adapter cna be fitted for you)
Your factory microphone can not be kept no matter whether you purchased the microphone adapter. you only can use our external microphone.
Thanks.
Add joy to your car with Joying!!!
Jpage978
North Shore Ma.
Been thinking about one of chinese brand android units, but doesn't look like any of them will support oem back up cam
SitKneelBend
St. Louis
3.6 Pentastar
I believe nearly all of them support the OEM camera. You just need to buy one advertised as being for a Ram.
Jpage978
North Shore Ma.
I'm having issues finding if there's a difference with interface and what harness to use on these classics, compared to something like an 2018 ram 1500, or if it's same
SitKneelBend
St. Louis
3.6 Pentastar
It should be the same for at least 2013-2021 (classics).
Jpage978
North Shore Ma.
Video says use certain harness sonic electronics says axxess axvi 6523
Forestry_Ridge
Wildland firefighter/EMT
Moscow, Idaho, USA
I don't see why not. The head unit is actually cheaper but you only get 2GB RAM/32GB ROM in the single din 10.1 units available on Amazon. You also lose the built in Apple CarPlay and Android Auto. They replaced it with a screen mirroring app in this version. Plus the quick buttons on the side are replaced with the volume slider. You can find the same screen I have on Joying's website but then you are paying close to the same price as the double din version. See above for the mounting kit you would need instead of the one listed originally. I have edited my original post to include the single din mounting kit and the correct mounting kit for Rams with touch screens.
Amazon - Joying Single Din 10.1 inch Android 8.1 2GB+32GB
https://www.amazon.com/dp/B07WGNQYZW/ref=cm_sw_em_r_mt_dp_U_AesCDbY0F8CKZ
Joying Website
https://www.joyingauto.com/joying-b...ation-system-10-1-touch-screen-head-unit.html
I’ve got one of the single din ones in my 2010 and it has CarPlay still.
