1SLwLS1
- Jan 8, 2013
- 127
- 131
- 2013
- Hemi 6.4
So my truck has been sitting for about 6 months and after getting it back up and running (8 speed trans swap), the speedometer started jumping around, same with the digital speed displayed on the EVIC.
I have checked all of the wheel sensors, that wiring is good. They all display similar speeds when live scanning in AlfaOBD. The output speed in AlfaOBD doesn't jump around like it does in the dash. I replaced the ABS control module with a used unit and ran an ABS initialization & cleared rolling codes via AlfaOBD but it is still jumping.
I am getting the U0002 from the ABS module (new and old) with Can C Bus Off Performance as the description. From the ECM, I am getting a U1412 Implausible Vehicle Speed Signal Received.
Nothing else seems out of place but it has been sitting a while. The transmission crossmember was welded in place so I suppose some weird voltage could have fried something but I already replaced the ABS control module. I am not really sure where to go from here. Any ideas?
