stickpony
Hi guys,
I just bought a high miles ( 280,000 )work truck, a 2004 Ram 2500 w/ the Hemi 5.7 engine.
The engine and transmission were replaced at some point so they run smooth as silk, but the suspension could probably use a freshening up
There’s a fair amount of squeaky when I go through parking lots at slow speed and over speed bumps, and there is also a popping/knocking sound coming from the front drivers side area when I am navigating turns into parking spaces, turning hard in one direction and then in the opposite direction, and also sometimes when going over speed bumps.
I guess my question is this: what are the main areas of wear that I should replace that are recommended on high miles 2500’s, and what might the ‘popping’ sound be on the front drivers side that is most noticeable going over bumps and navigating parking lots?
Thanks in advance for the advice.
