kayjo
I just bought a 2019 with about 8ok mi. I am wanting a synthetic oil strategy. The vehicle is one owner, seems to have been used mostly for a traveling related job. Put consistent mileage each month. Timer suggests average speed of about 40MPH. and idle hours less than 100. That is about 4%. Truck is a bit noisy on startup but quiets down after a minute or two. So obviously there is no residual lubrication effect for a cold engine. Now over 80ks mileage, should I be going to 5w30? or using something , like additive , that can bond to surfaces.(moly?)
I have read all sorts of things about quieting tick, however, I just want good cold start protection plus more assured protection for lifters as we are getting up there in mileage. Should I be using something that should clean the lifters, Or perhaps a high mileage oil. I noted that noted that many people in the forum use the RP 820 larger filter but not RP oil. I was looking at high mileage oils and I like how RP sounded. they do mention added zinc and phosphorus also. I would like to use lube guard as well for the moly. But I know a lot of oils have moly in it. Am I ready for redline without tick? as a preventative? I think amsoil is probably a really good oil. But do not think it has the detergents and solvents that I would like to use to make sure lifters are properly clean before addressing good lubrication moving forward. I do not hear too many people using additives, a couple like seafoam. and I have seen some use MMO. I havent use that in more than 40 years, and not sure if that is the additive to use here on these trucks.
So my thoughts of now are using RP high mileage for its cleaning, and adding lube guard for its moly and cold start protection. Or using penzoil ultimate high mileage which already seems to have a lot of added moly? doesnt seem to do any zinc.
