Key fob problems
Wrenchmike3500
North Carolina
6.7 cummins turbo diesel
I have a 2021 ram 3500drw cummins tradesman2 level at random times it displays key fob not detected when i attempt to start it and at times going down the road it wll display key fob has left the vehicle the dealer i purchased it from has checked it 1 time and could not get it to replicate problem since it has no rhyme or reason as to when it happens now they refuse to work on it because they cant authorize a rental to keep it till it does it justcurious if anyone has haad same problem or knows te solution also battries are new and work fine with good range for lock unlock
Gommer
Rogers, AR
2020 1500, 2018 2500
5.7 and 6.7
Sounds like a short of some kind causing an internal sensor(s) to fail.
Take it to a better dealer would be my best suggestion. It could be as simple as a loose harness or could be as ugly as a bad wire inside a loom.
Wanted33
Down South in Dixie
5.7L
Try a new battery in the FOB. I had a FOB battery go dead in 2 weeks after buying a new F-150. Hopefully it's a simply cure like that.
Wanted33
Down South in Dixie
5.7L
Me too. The FOB battery I used lasted one day.
Yeah, there's no to know how long those batteries sit on the self before the manufacturers use them. When I took my F-150 back, the Service Manager (who I've know forever) just smiles, and said let me get you a new battery. Done, and done........
BossHogg
Oakland Township, Michigan
6.7L Cummins
Like others suggested check the battery, these batteries are difficult to test and if you replace the battery, use a brand name like Energizer or Duracell, this comes from experience. These later FOBs have a small red LED that illuminates when a FOB button is pushed, are you seeing the red LED illuminate? Another good test is to try the second FOB and see if you get the same behavior. Try placing the FOB you are having issues with within the vehicle somewhere outside your pocket and see if the issue repeats.
I had a similar issue and discovered the FOB in my pocket was covered by my cell phone in the cargo pocket of my shorts. There is a discussion about FOBs and cell phones in the owners' manual.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
There is a known issue with key fobs and aftermarket LED's on 1500's. People upgrade some or all of their bulbs to LED and then start experiencing issues with their fobs. This has also happened with garage door openers with LED lights. I don't know if this is also an issue on HD's, but I thought I'd mention it.
austmurr
