Ok got the gb12 and the jl hd750 installed.....I was feeling a little frisky and came across a used pair of c3cx's and ending up buying them too!. I Know I know I couldn't help myself.
Ok first the c3cx's are ridiculously clear and just sound amazing. I may have to take down the tweeter db a touch on the included crossovers as my ears may get fatigued, but I'll give it a few days.
The jl hd750 and the gb12 are installed and sound really good. Though I feel I may need to do more adjustments, specifically when it comes to setting the gains.
I used a cheap oscilloscope
https://www.amazon.com/dp/B07QML4LJL/ref=cm_sw_r_cp_apa_fabc_Jy5aGbFHR9EXQ?_encoding=UTF8&psc=1 to try to set the gain. Keep in mind I have never used one before and went off a few youtube videos.
I had the head unit volume at 34 (my sorta max volume), played a 50hz 0db tone, set the scope to 20v, AC, 5mm. Keep in mind all settings on HU flat, amp settings were LPF 90.
I was able to clearly see the wave coming from the amp outputs. But it clipped extremely early, almost too early? I barely moved the gain past the zero mark.
My question is do I need to scope the waves prior to the amp? I have the factory 8.4 going to a pac amp pro to get a clean signal, but I feel like maybe I'm getting clipping so early when testing the amp output signal is because I'm using such a high HU volume ?
