kicking
kitz
donnellson iowa
5.9 gas
hey all. new here HI. have a question about a 2001 ram 5.9 gas engine. this happened before I put a new computer in because it would not start and still does. but when I start it once in awhile it seems like it will kick like a old tractor would do. I thought of timing but I can not find what timing should be. this engine has 125000 miles. even after new pcm it seems like it takes awhile to start. after its running it runs fine any ideas tia
318_performance
Kinmundy IL
318 c.i.
Well first off do you have fuel, air, an spark? Before you start do you hear the fuel pump start? Have you takin a plug wire off an hooked up a extra spark plug to see if you have spark?
K
kitz
donnellson iowa
5.9 gas
it will start now I didn't have power to coil and had 601 code that is why I put on a new pcm sorry my writng sounds like it wont start now but it does and runs ok it is just once in a while it will kick when I do start it
318willrun
Midwest
What's a "kick".... Backfire through the exhaust or throttle body? Or the starter acts like it doesn't have the power to turn the engine over for a split second?
K
kitz
donnellson iowa
5.9 gas
kind of like a compression relief on a lawnmower engine if that makes any sense
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
something is off, check your plug wiring, and replace the button that spins. they are fairly cheap - $10 or so. If you find anything along the way that looks out of order, remove inspect and replace if needed.
Immerge
