KOOKS long tubes+catted mid pipe install and sound clips
ramportin1
Sickest member here
Oregon
I found I had a broken manifold bolt and decided hey, let's replace it with some really expensive long tubes lol anyway, of course installing did not go smoothly (when does it ever honestly) so I figured I'd post up some not so expected issues I ran into as well as post up all the pictures I took. Also I did take a before cold start video (which is stock manifolds and cats, resonator delete to a 10 series dumped) and I'll take a after cold start video here shortly and post up to compare, which is KOOKS long tube headers to KOOKS catted mid pipe to my trusty 10 series and dumped again. I'll also give some revs and TRY to do a WOT fly by if possible. I will say the sound is top notch, super deep tone, crazy aggressive and just SCREAAAAAMS at WOT. Could not be happier with sound. For all you drone pansies (no offense) this is not the set up for you, drone is intense lol but I love it.
Absolutely HAVE to thank NICK@GOTEXHAUST again for coming through for me and being such a good dude. Awesome customer service this guy, I HIGHLY recommend anyone looking at mods to hit him up first. It can't hurt
PROBLEMS TO EXPECT: 1* Passenger side header will hit the motor mount bracket and require you to grind down the bracket, grinding it down quite a large amount will give you the clearance needed for install AND so your tube doesn't clank every time you hit a bump or WOT and torque the motor.... I wasn't very comfortable grinding that much out so I grinded some and then dented the one tube in a bit to give me that extra room.
2: as with most headers, getting the bolts in some of the lower holes is right next to impossible and to torque em properly is impossible unless you have some major boss tools. 2 bolts I had no choice but to torque the old fashioned way and just feel for it.
3: driver side header will also hit the same motor mount but it's much better then the pass. Side. Only thing I had to do here was grind back about 6-7 threads back of the motor mount bolt that's through the nut, that gave me the perfect amount of room.
4: trans cooler lines on pass side will be pushed against the header, I had to remove the bracket and carefully bend them away enough that I was comfortable with.... to do this carefully is pretty tedious and frustrating lol, at this point I had busted about every damn knuckle and screamed every curse word imaginable ha.
5: KOOKS did NOT supply a single split lock washer for the header bolts...... not sure if that was a mistake or they seriously expect someone to install headers with no lock washers. So grab yourself at least 16 of those.
6: KOOKS also did not supply a band clamp for the Y-muffler or cat back. This I guess is not necessarily on them but I would have hoped for as much as KOOKS costs they would've of supplied that.
7: Not a big deal but worth adding, I threw a P0420 code within a half hour. So if you don't have a tuner to be able to tune out your 02 sensors you will be stuck with a check engine light most likely. I'll be hitting Sean up tomorrow lol.
I think that's it... if I think of anything else I'll add it. I will upload some videos here shortly maybe a day or 2.
For what it's worth, I am a bald eagle screaming nitro fume smelling junkie lol I love LOUD deep raspy muscle. I was hoping for a ridiculously loud truck after this (keeping in mind it's mostly stock) with a super aggressive deep tone and this set up is every bit of that. Super stoked. 06780b20db53483d79ef4c10fb81213b.jpgfc272a36ef3cc2d8dea15e1229ef6ad9.jpg173f84e2e3e792aec0cd054761d39e89.jpg707e94a3e70969ff0c57220876861acf.jpg59524a8b45401fd733533bb038cc1965.jpg04b7c1ffe15df91cb264b3d4e837af02.jpgc48550400fbddd0575d8c2d983c5b67c.jpgcb41a562c72a4849a06b092d2bc8cd63.jpg
ramportin1
ramportin1
Sickest member here
Oregon
Here's the mount that I had to shoulder and the tube after being dented in. Think I did a pretty dang good job if I say so myself lol
ramportin1
ramportin1
Sickest member here
Oregon
And here's how all the piping looks and my all time favorite muffler. I'll try and get the videos up soon as I can
Nick@GotExhaust
Preferred Vendor
SC
Looks great! Nice work. Thank you for the shout out! Also can't wait to hear that setup. I have no doubt women and children will be hiding in fear when Raiden comes down the street.
Sent from my XT1650 using Tapatalk
VF_Mike
Looks great and thanks for posting. I have mine sitting here and this atvleast gives me a heads up.
Thanks again
ramportin1
ramportin1
Sickest member here
Oregon
For sure bro, thank you!
ramportin1
ramportin1
Sickest member here
Oregon
Thanks again
They are worth the little bit of hastle, they sound soooo damn good!
ramportin1
ramportin1
Sickest member here
Oregon
Well im having some technical difficulties uploading the videos to youtube, never done it before. The videos are just recorded on my phone (so sound is not very great but still) and i have my phone plugged into my computer via usb, im in the upload section of youtube and i drag the video into the "drag to upload" box and nothing happens. then if i try to save the video to my computer first it says my device is not functioning..... no clue
ramportin1
ramportin1
Sickest member here
Oregon
https://www.youtube.com/watch?v=VyDCn3GWvME
Sound after. recorded on my phone so the sound sucks.... im going to try and borrow a camera from my buddy and then do some revs and maybe a WOT. ill update here when i get some better videos. this was at 5:45AM heading to work so yeah, excuse me if im a little slow lol
chrisp2493
Always Modding
Warren, OH
392 Hemi
Cam it!!!! Cam it!!!! Cam it!!!!
Hahaha
It sounds awesome! Great job
ramportin1
ramportin1
Sickest member here
Oregon
Hahaha
:roflsquared: bro, my very first start up i go "ohhhhhhhh F*** YES that sounds sooooo good....... just imagine this set up cammed..." lol! the truck is going to take a mild break from mods (allegedly lol) the exhaust costed a pretty penny... then a cam might just have to happen idk we'll see :crazy:
i really got to get a decent camera to get the real sound, my phone does it about 2.5% justice lol
chrisp2493
Always Modding
Warren, OH
392 Hemi
Haha yeah after this engine is done my bank account is gonna have to go into hiding for awhile too maybe one day I’ll pull my 260 out, sell it and replace with a custom grind
Nick@GotExhaust
Preferred Vendor
SC
Sounds really good bro. Got to borrow someones camera and do some revs and a wot throttle take off vid! :favorites13:
a cam would compliment that exhaust rather nicely :flamingdevil:
ramportin1
ramportin1
Sickest member here
Oregon
Bro it's so frustrating! I did a rev video, seriously ear drum shattering almost, watched it on my phone, hardly sounds like anything lol. I gotta borrow a camera
Nick@GotExhaust
Preferred Vendor
SC
I know what you mean. My mustang is LOUD with headers, off road x pipe and SLP LM1's. i did some videos using my phone and it sounds no where near the screaming bald eagles loud it is in person.
ramportin1
ramportin1
Sickest member here
Oregon
Ahh yes the fox, you know exactly what I'm saying lol
ramportin1
ramportin1
Sickest member here
Oregon
Ok so after driving around quite a bit today I can without a freaking doubt say that this set up + updated tune has increased the low-mid range power a very noticeable amount. I can't believe it really, I mean I knew if you actually had before and after track times you'd see the improvement but I never thought it would be big enough to feel just normal driving around. Multiple times today I found myself taking off from a light (I notoriously drive like a "grandma ") and actually letting off the throttle slightly kuz I was like whoaa lol easy raiden [emoji23]. 1st gear right around the 2200 range it really wants to go lol same as 2nd. Bad A$$ [emoji41]
chrisp2493
Always Modding
Warren, OH
392 Hemi
Careful, this is where the mods start to get addicting...
