Lamin x vs yellow bulbs (fog lights)
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Morimoto requires you to replace the stock housings and they are one color. I was offering an LED upgrade that installs with no tools in minutes and offers BOTH White and Yellow light. And if you install the LED's properly their is a perfect non-blinding cutoff.
Ok I get your point
No tools,
2 color LED
Who has installed LED anything correctly their first try?? :005:
Last point sadly is false the fog light housings have zero cutoff. Ask me how I know :D
This is LED in stock housing above.
Morimoto below
You can see how the cutoff works in the above two photos. They don't scatter light like any LED bulb in the stock housing.
For the installation of the Morimoto LED you remove the stock fog light housing. Remove the bracket that will be reused on the new fog light housing. Then install the new fog light with brackets. Make sure and aim them. Youtube is a great source for more info on that part. Enjoy:cheers:
AE5548
NH
Newer style LED bulbs have a great cutoff line when you orient them properly in the housings. The LED chips don't throw light 360. They are 180 degree apart. It's the HID and cheap LED's that throw light everywhere and blind people. Been using mine for over 6 months and never been flashed and set them up against a garage door. I have a similar pattern to yours at night.
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
Anyone know what type fog light bulb is in the Warlock?? Everything I look up asks if I have vertical or horizontal fogs, I have round??
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Show me whatcha got.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
One on left, sorry don't have better pic on this computerView attachment 233795
Ok couple first for me.
Now your fog light orientation would be horizontal. I'm guessing that is depending on the Rebel/Warlock front bumper.
Sport trucks like mine have Vertical. Terrible for LED in the stock housing. So I went with Morimoto pictured.
Yours look almost projector like in the stock housing. I need to research somemore to find a better answer.
Found a couple of my aiming photos when I first installed them. This is the Morimoto LED aimed on my 7" lifted Ram.
Last photo is just a quick pic halfway through the install of the new Morimoto LED fog light
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Ok so with the Rebel/Warlock this are OEM LED sealed fog lights. It does not look like the bulb is survivable unless modified. Lamin-x would be the cheaper solution it appears.
Does an aftermarket Rebel/Warlock fog light exist?
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
Seems strange if they aren't replaceable bulbs but I cant find squat about them? Maybe I can try a Rebel group?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I would need a better detailed pic to see what you're working with. Actually my neighbor has a Rebel. I'll snap a photo of his to confirm.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Found it.
"The 2019 Ram 1500 Classic Warlock, which made its debut at the Toronto Auto Show, features a black grille with bold R-A-M lettering, 20-inch semi-gloss black aluminum wheels, front and rear powder coated bumpers, 1-inch factory lift, black wheel flares, LED fog lamps, projector headlamps with dark bezels, LED rear tail lamps, black badging, tow hooks, unique hood decals, heavy duty rear shocks and an optional Sport hood. Warlock decals on the bedsides round out the package."
https://www.fcagroup.com/stories/northamerica/en-us/Pages/2019_ram_1500_classic_warlock.aspx
hunterdan
hunterdan
SE PA
2019 classic
I'm going to assume here, that the housing mounts exactly the same as the reflector housings and probably even uses the same plugs.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Doesn't look like any type of conventional bulb in the Rebel fog light either.
My neighbors stock Rebel for reference
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Perhaps but would someone really buy $130 reflector housings, $50 + on whatever brand LED bulb just to get a yellow colored bulb??
Yeah they probably would huh...:Big Laugh:
az chip
Phoenix
Just found it is my problem as well. Took a chance and did not win. These are sealed units. No bulb.
2016Bighorny
Wisconsin
I have these and love them! Bright white light when driving in regular weather conditions, and bright yellow when driving in the fog and snow...
mmcquinn
