Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Lamin x vs yellow bulbs (fog lights)
Discussion in 'Exterior' started by hunterdan, Jan 2, 2021.
Sponsored By: BAK Factory Outlet
  1. RedSRT4Me
    RedSRT4Me Senior Member
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    Ok I get your point
    No tools,
    2 color LED
    Who has installed LED anything correctly their first try?? :005:
    Last point sadly is false the fog light housings have zero cutoff. Ask me how I know :D
    This is LED in stock housing above.
    Morimoto below
    You can see how the cutoff works in the above two photos. They don't scatter light like any LED bulb in the stock housing.
    For the installation of the Morimoto LED you remove the stock fog light housing. Remove the bracket that will be reused on the new fog light housing. Then install the new fog light with brackets. Make sure and aim them. Youtube is a great source for more info on that part. Enjoy:cheers:
  2. AE5548
    AE5548 Senior Member Supporting Member
    247
    269
    Jun 19, 2020
    NH
    Ram Year:
    Engine:
    Newer style LED bulbs have a great cutoff line when you orient them properly in the housings. The LED chips don't throw light 360. They are 180 degree apart. It's the HID and cheap LED's that throw light everywhere and blind people. Been using mine for over 6 months and never been flashed and set them up against a garage door. I have a similar pattern to yours at night.
    Ramm5.7 likes this.
  3. Skyjockey
    Skyjockey Senior Member
    297
    67
    Aug 22, 2012
    Lowell MA
    Ram Year:
    Engine:
    3.6L
    Anyone know what type fog light bulb is in the Warlock?? Everything I look up asks if I have vertical or horizontal fogs, I have round??
  4. RedSRT4Me
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    Show me whatcha got.
  5. RedSRT4Me
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    Post a pic of the truck. Fog light bulb number is 9006.
  6. Skyjockey
    297
    67
    Aug 22, 2012
    Lowell MA
    Ram Year:
    Engine:
    3.6L
  7. RedSRT4Me
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    Ok couple first for me.
    Now your fog light orientation would be horizontal. I'm guessing that is depending on the Rebel/Warlock front bumper.
    Sport trucks like mine have Vertical. Terrible for LED in the stock housing. So I went with Morimoto pictured.
    Yours look almost projector like in the stock housing. I need to research somemore to find a better answer.
    Found a couple of my aiming photos when I first installed them. This is the Morimoto LED aimed on my 7" lifted Ram.
    Last photo is just a quick pic halfway through the install of the new Morimoto LED fog light
  8. RedSRT4Me
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    Ok so with the Rebel/Warlock this are OEM LED sealed fog lights. It does not look like the bulb is survivable unless modified. Lamin-x would be the cheaper solution it appears.
    Does an aftermarket Rebel/Warlock fog light exist?
  9. Skyjockey
    297
    67
    Aug 22, 2012
    Lowell MA
    Ram Year:
    Engine:
    3.6L
    Seems strange if they aren't replaceable bulbs but I cant find squat about them? Maybe I can try a Rebel group?
  10. RedSRT4Me
    1,848
    1,272
    Oct 28, 2015
    Scottsdale, Az
    Ram Year:
    2015 CC Sport
    Engine:
    I would need a better detailed pic to see what you're working with. Actually my neighbor has a Rebel. I'll snap a photo of his to confirm.
Share This Page
